Author Topic: Is the timing too advanced?  (Read 4516 times)
October 02, 2008, 12:24:44 pm
  • 3468
    • McScrubbins Body Wash
« on: October 02, 2008, 12:24:44 pm »
How can one tell if the IP timing is too advanced? what ill effect occur with very advanced IP timing?
things to look for, notice, extremes, and so on
Reply #1October 02, 2008, 01:03:00 pm
Re: Is the timing too advanced?
« Reply #1 on: October 02, 2008, 01:03:00 pm »
Quote from: "Smokey Eddy"
First thing you will notice is it sounds like someone threw a couple handful's of marbles into the engine (LOUD).
It can raise cyl pressures to dangerous levels causing blown head gaskets etc.
You will see white smoke if it's advanced to far as well.
On the other side, it starts easier and the EGT's will be lower. More top end power...
Just have to fine the break even point for your car and your type of driving.
Reply #2October 02, 2008, 08:50:17 pm
Op-Ivy
  • 513
« Reply #2 on: October 02, 2008, 08:50:17 pm »
Also, it may be hard to start if it is too far advanced. Hesitant starting.
And sometimes those marbles will be just barely audible. Listen carefully. If you here them at all you are too far advanced.
Reply #3October 04, 2008, 11:54:01 am
  • 3468
« Reply #3 on: October 04, 2008, 11:54:01 am »
That's exactly what it sounds like. - tons of rattling stones or something. hesistant starting and i seem to go through HG's pretty quick
Sure picks up FAST right at the end of the top of the rpm range though (60km/h in 2nd gear)
