Author Topic: Changing Glow plugs!? @#$#@%#^#%^  (Read 9461 times)
Reply #15June 25, 2005, 09:52:41 pm
vixentd
  • 88
glowplugs
« Reply #15 on: June 25, 2005, 09:52:41 pm »
Use the heavy wire works fine, but if you do not have that take your bus bar off.  Carefully cut a v into it just below the holes.  Now put he nuts on the glowplugs before installing.  Don't tighten the nuts yet, just drop the bus bar down after the glowplugs are tight.  then snug up the 8mm nuts.  Quick and easy. To check for a bad glow plug, loosen the end nuts, slide the bus bar off and you can check easily.
