Author Topic: My 1.6td/aaz head and other stuff too.  (Read 124710 times)
Reply #105November 11, 2008, 10:01:43 am
TurboJ
  • 661
My much anticipated 1.6td/aaz head.
« Reply #105 on: November 11, 2008, 10:01:43 am »
Quote from: "Smokey Eddy"
Which do I have?
130?
I think the 90 hp TDI at least has a manifold like the one in your picture. I had one with engine code ALH on a Skoda Octavia.
Jetta II 1.6 TD 'Project 200'
Reply #106November 14, 2008, 04:46:43 pm
  • 3468
    • McScrubbins Body Wash
« Reply #106 on: November 14, 2008, 04:46:43 pm »
Quote from: "zukgod1"
The shaft wont come out with the engine in the car.
That cap does hold it in but its not gonna fall out if you remove the cap to replace the seal and gasket.
What are you talking about "pay for new one"? The seal? $5. maybe.
I just got back from wakefield sperling...
they want over 25$ for one intermediate shaft seal. I said immediately screw that.
That would have made my parts consisting of:
a HG, rod bearings, intermediate shaft seal and timing belt $150.00... :?
Which is rediculous. I'm not paying that.
I'm going to pay 50$ for the head gasket and probably re-use the rod bearings. and the timing belt was 40+ dollars... i remember paying 22$ for my last one which still looks fine... i may just keep using it and get a new one when i have more money.
Where on earth do you guys get parts for so freakin cheap???
Reply #107November 14, 2008, 05:01:57 pm
rallydiesel
  • 1880
« Reply #107 on: November 14, 2008, 05:01:57 pm »
I get my stock replacement stuff from:
http://www.importcarpartscanada.ca/index.wws
Shipping's fast and prices are good. Plus they tell you the manufacturer before you order  :wink: .
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #108November 14, 2008, 05:13:04 pm
  • 3468
« Reply #108 on: November 14, 2008, 05:13:04 pm »
This site asks $53 for what the what the, i thought, "cheap" parts store is asking over $120 for.
but they don't have some items i'd want.
They only have a 2 hole aaz head gasket. I'd want a 1 hole :(
what is the difference between "web only" price and "list price" ???
Reply #109November 14, 2008, 05:23:19 pm
rallydiesel
  • 1880
« Reply #109 on: November 14, 2008, 05:23:19 pm »
The web only price is what they charge. The list price is just a marketing thing but it's probably not far off what a dealership would charge.
Reply #110November 14, 2008, 08:35:26 pm
  • 3468
« Reply #110 on: November 14, 2008, 08:35:26 pm »
Quote from: "rallydiesel"
I used that site  :D  :D  :D  :D  :D  :D  :D  :D
got LOTS of extra stuff and it was still under $120
Gosh Wakefield is gonna be sad when i tell em i got a way way way way better price.
That place in the link is in Alberta!!  Half the freakin' tax. That's so awesome. And like 2 days to ship to my house for free. What a score. That site is going to be re-visited im sure.
I had to settle for a 2 notch HG though. They didn't have a 1 notch metal one. The difference is so minute i really don't think it will be a big deal. It will help a little i guess with the added boost.
Edit: im retarded, it's ontario.
Reply #111December 05, 2008, 03:59:34 pm
  • 3468
Update
« Reply #111 on: December 05, 2008, 03:59:34 pm »
Update time. Yay pictures
Drilled and tapped that cock sucker last night!
Plugged my waste gate
Got my guages in
New White dash LED set up
My new lead terminals. I replaced the pre-existing ground with a huge one and moved the old ground to ground to the body. I hope it will crank faster now :P
My two huge out put V6 Taurus fans. I'm currenty drawing up a template for a shroud and frame for the fans. I'm also going to modify the front end to fit my intercooler aswell.
And last but certainly not least, my ported, gasket matched, ALH intake ready to pwn. Notice the BOV delete ;) I reccomend this swap for an AAZ head.  I had to modify the elbow though. I put a silicone elbow on it that you can swivle for any intercooling possitioning you want. It's totally versitile. I added a lip too for a better seal.
Reply #112December 26, 2008, 02:57:04 am
  • 3468
« Reply #112 on: December 26, 2008, 02:57:04 am »
Finally got the right valves and threw it together!
I made this sort of magnetic V block for drilling the block's steam holes while it's in the car.
Coming along nicely now!
Just need to do exhaust, rad/intercooler mount, fans and plumbing after i get the ring set.
Reply #113December 26, 2008, 07:36:11 am
spencebm
  • 686
« Reply #113 on: December 26, 2008, 07:36:11 am »
how hard was it to slap that egt gauge in there?
Ben Spencer
Reply #114December 26, 2008, 02:16:47 pm
  • 3468
« Reply #114 on: December 26, 2008, 02:16:47 pm »
Oh, not at all. The bits tend to catch the cast and complain a bit but if you have good quality bits they shouldn't break. Use lots of oil.
I put the mani in a vice and it was easy! The threads for the sender mount is tapered so you just have to choose the right thread pitch and stuff. start small because you can always drill out the next size up.
Reply #115December 26, 2008, 06:45:58 pm
Rabbit TD
  • 840
Valve spring compressor
« Reply #115 on: December 26, 2008, 06:45:58 pm »
Smokey, are you talking about cutting a groove in a deep welll socket for getting to the valve keepers.  I found that my oxygen sensor socket fit right in the bore and used a plain old $25 valve spring compressor to push it down, and you can get to the keepers easily, couldn't have worked any better' :)
Reply #116December 26, 2008, 07:26:50 pm
  • 3468
« Reply #116 on: December 26, 2008, 07:26:50 pm »
That's refering to a very old post?
I made this out of a bicycle seat post.
I later ground the opening wider.
Combo that with a normal wood working clamp and a table and it works fine with needle nose pliers.
Reply #117December 28, 2008, 02:01:24 am
  • 3468
« Reply #117 on: December 28, 2008, 02:01:24 am »
Are those pictures too big? do they take forever to load?
Reply #118January 02, 2009, 12:56:15 pm
  • 3468
« Reply #118 on: January 02, 2009, 12:56:15 pm »
Finally!
Here are the bolts i put on the LDA. I think anyone doing any work on their IDI should change those stupid slotted bolts our for real ones.
You can see the ALH intake, NEW HEAD! :D, and continental timing belt here! neat stuff. Finally moving forward.
Still need to add a nipple in the boost side of the turbo closest to the intake for the LDA and gauge to get pressure from.
Reply #119January 02, 2009, 01:06:19 pm
  • 3468
« Reply #119 on: January 02, 2009, 01:06:19 pm »
Here's the cam cover Burn Your Money (Tyler) sent me. It didn't look like this when i recieved it :P but it looks good now!
