Author Topic: gli exhaust mani  (Read 1994 times)
September 17, 2008, 09:09:09 pm
shegel
  • 312
gli exhaust mani
« on: September 17, 2008, 09:09:09 pm »
im planning on changing out my exhaust tommorow. but i lent my bentley to my friend for his 1.6 rebuild project. can the exhaust mani be removed while in the car. and can i install the the new mani in its place without much difficulty?
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #1September 18, 2008, 10:12:05 am
gli exhaust mani
« Reply #1 on: September 18, 2008, 10:12:05 am »
I don't know about "without much difficulty" but it can be done..
Shouldn't be to bad really.
Good luck.
Reply #2September 18, 2008, 10:22:10 am
Op-Ivy
  • 513
gli exhaust mani
« Reply #2 on: September 18, 2008, 10:22:10 am »
It shouldn't be too hard. All of the bolts holding it on are obvious. No really hidden ones. 8 holding it onto the block and a few smaller ones holding little bits on IIRC.
Use liquid wrench or wd40 if they are rusted like mine are.
Reply #3September 18, 2008, 10:24:57 am
dieselwagen
  • 85
Re: gli exhaust mani
« Reply #3 on: September 18, 2008, 10:24:57 am »
Quote from: "shegel"
it will be easier to remove the intake manifold first to get clear access to #2 & #3 exhaust manifold top bolt, otherwise it will be tricky getting a straight shot at those manifold nuts, WD-40 sometimes makes removal a breeze.
yes the exhaust manifold can be removed while it the car.
1986 golf 1.6
