Author Topic: VW Syncro TDI  (Read 8628 times)
June 07, 2004, 08:53:48 am
BlackTieTD
  • 1512
VW Syncro TDI
« on: June 07, 2004, 08:53:48 am »
will a gearbox from a VW syncro system bolt up to a TDI engine? i don't know much about the newer engines.. but i've seen a couple cars with mkIV engines, and syncro drivetrains, i wonder if its all bolt up? very doubtful..  :lol:
Reply #1June 07, 2004, 01:58:27 pm
RedRotors
  • 734
    • http://www.mikrotuning.com
VW Syncro TDI
« Reply #1 on: June 07, 2004, 01:58:27 pm »
Bolt - on.
Marc/
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
-> www.mikrotuning.com <-
-> www.hflox.com <-
Reply #2June 07, 2004, 03:09:17 pm
Blades
VW Syncro TDI
« Reply #2 on: June 07, 2004, 03:09:17 pm »
SyncroNorm had a Passat G60 Syncro that he had converted to TDI :)
I still wish I had bought it ....
All VW 4-cylinder transmission are bolt-on to any VW 4-cylinder engine.
You only need the right clutch/flywheel combinison
Reply #3June 08, 2004, 07:59:19 am
MrDave
  • 41
Re: VW Syncro TDI
« Reply #3 on: June 08, 2004, 07:59:19 am »
Quote from: "BlackTieTD"
The syncro gearbox from the G60 Passat Syncro is an 02C.
The 02C is a sister gearbox to the 02A.
The R&P and gearset from an 02A gearbox are a direct fit
into an 02C case.  It's fairly easy easy to do the parts swap.
I currently have an 02C case with a 3.16 final and TDI gears sitting on my engine stand.
Regarding the case fitting, general rules of thumb for VW:
1a. all 4 cylinder trannies fit to all 4 cylinder engines
    (a 1974 020 4spd will bolt on to a 2004 1.8T)
1b. the VR6 bellhousings don't bolt up to the 4 cylinder engines
     (you can't bolt an 020 gearbox up to a VR6)
2. use the clutch that goes with the transmission
     (For 02A gearbox use 02A clutch.  For 020 gearbox, use 020 clutch)
-Dave
Reply #4June 08, 2004, 04:57:52 pm
Dr. Diesel
  • 1341
VW Syncro TDI
« Reply #4 on: June 08, 2004, 04:57:52 pm »
i have an engineless passat syncro in my shop. putting the engine into a dude's A1 jetta.
A friend is buying the chassis to install the syncro system into an A2 jetta with a  supercharged 2L 16v.  too bad!
