Author Topic: Alternator Question  (Read 8802 times)
Reply #15September 06, 2005, 08:43:04 am
rackley
  • 96
Alternator Question
« Reply #15 on: September 06, 2005, 08:43:04 am »
Hey fspGTD, can you elaborate on your alternator and Transpo self-exciting regulator?  I want to use my WVO Jetta along with an inverter as a low-wattage (TV, radio setup) generator for tailgating, but with the way the alternator is designed it will leave me with a dead battery very quickly.  I searched on the Transpo site and the only regulators they list for our alternators are NOT self-exciting.  Details please?  :D
Thanks,
Ray
www.vocontrol.com
VO Control - Programmable VegOil and WVO Controllers
Reply #16September 06, 2005, 09:23:01 am
fspGTD
  • 1529
Alternator Question
« Reply #16 on: September 06, 2005, 09:23:01 am »
It's a totally different alternator I put on there that is self-exciting, made by Denso (as in Nippon-Denso).  Denso is not an OEM for volkswagen.
Jake Russell
Reply #17September 06, 2005, 09:43:38 am
VWRacer
  • 649
Alternator Question
« Reply #17 on: September 06, 2005, 09:43:38 am »
When my diesel's alternator went belly-up I installed a single-wire, self-exciting alternator (intended for a GM application) in place of the dedicated diesel alternator. I bought it at NAPA for $90. I had them install the smallest pully they had (about 2.5") so that it would start charging as soon as the engine turns over. Works beautifully - I get 14 volts at dead idle.
Stan
C-Sports Racer
Reply #18September 06, 2005, 10:14:12 am
rackley
  • 96
Alternator Question
« Reply #18 on: September 06, 2005, 10:14:12 am »
Do you happen to have any info on that alternator, like a part number?  My local NAPA people just punch the make/model and call it a day, they don't know anything beyond that.  Also, are you talking about the 90A or the 60A alternator?
www.vocontrol.com
Reply #19September 06, 2005, 10:52:09 am
VWRacer
  • 649
Alternator Question
« Reply #19 on: September 06, 2005, 10:52:09 am »
Yep... :)
Napa Power Supreme
Alternator # 13-4011SW
Rated 63 Amps (60 amps nominal?)
Stan
C-Sports Racer
Reply #20September 06, 2005, 11:20:38 am
rackley
  • 96
Alternator Question
« Reply #20 on: September 06, 2005, 11:20:38 am »
DOH!  That probably won't fit in my 90A spot then.
www.vocontrol.com
Reply #21September 06, 2005, 12:02:53 pm
VWRacer
  • 649
Alternator Question
« Reply #21 on: September 06, 2005, 12:02:53 pm »
I don't think there's any physical difference between the 60A and the 90A. In any case, I had to shim the alternator into place with washers, so if you can fit the 90A in there I'd give it a try.
Stan
C-Sports Racer
Reply #22September 06, 2005, 01:52:05 pm
Patrick
  • 1034
Alternator Question
« Reply #22 on: September 06, 2005, 01:52:05 pm »
Quote from: "VWRacer"
Yep... :)
Napa Power Supreme
Sounds like a standard Delco 15si set up as a single wire. The 15si was used for a lot of years in almost anything GM sold, so a core shouldn't be a problem.  Any starter/alternator shop can do this, and you can run a "W" terminal off this alternator too, I have one that came in my perkins powred chevy truck.
Reply #23September 13, 2005, 06:41:44 am
rackley
  • 96
Alternator Question
« Reply #23 on: September 13, 2005, 06:41:44 am »
BTW, the alternator listed didn't even come close to fitting.  The mounting points are 180* apart on the alternator and the top mounting arm needs one that is about 120* or so.
www.vocontrol.com
Reply #24September 13, 2005, 01:11:58 pm
Patrick
  • 1034
Alternator Question
« Reply #24 on: September 13, 2005, 01:11:58 pm »
You could modify the mounting arm................
