Author Topic: After replace cylinder head & valves engine vibrates at  (Read 2556 times)
September 06, 2008, 05:32:22 am
Yellowfox
  • 5
« on: September 06, 2008, 05:32:22 am »
Hello about 1 month ago I had to replace te the cylinder head, intakes valves, and piston rings becouse mines was cracked but now after 110km/h I fell that my engines now vibrates a lot, someone with the same problem???
Some Information obout he engine:
car: Golf mk3 GTD AAZ 1.9
-intakes valves new
-new piston rings
-original vw cylinder head
-some problems with IP or injectors (some problems at low rpms some little fails I will take it to someones who nows) could this be the problem??
Thanks and sorry for my englis Im agentinian
 :oops:
Franco GOLF GTD 97 From Argentina
Reply #1September 06, 2008, 05:35:40 am
gigaz2
  • 626
« Reply #1 on: September 06, 2008, 05:35:40 am »
you should sort the injectors. new nozzles are almost always in order (if you haven't done that yet)
Reply #2September 06, 2008, 05:45:15 am
« Reply #2 on: September 06, 2008, 05:45:15 am »
Yeah start with the injectors. Make sure to have them calibrated with the new nozzles
Reply #3September 06, 2008, 08:04:26 am
« Reply #3 on: September 06, 2008, 08:04:26 am »
now when you say vibrate... explain.  does the car shimmy?  does it 'cut out' is it only when you go 110? 100 is fine?
Reply #4September 08, 2008, 05:45:20 am
Yellowfox
  • 5
« Reply #4 on: September 08, 2008, 05:45:20 am »
Thanks all of you, and jtanguay i fell that after 110 the engine is too noisy (a lot of tac,tac,tac on low rpms and noisy in higth I thinks this is related with te injectors, but the vibration too??)  and y fell some little vibration, wheels are ok, balanced about 1 moth ago and tires had run only 10000kmt
Thanks again for the tips an De-Code my english :D
Greetings
Reply #5September 08, 2008, 07:15:58 am
« Reply #5 on: September 08, 2008, 07:15:58 am »
Yes injectors are in order sir ;)
They will cause your car to shake at idle and anything under 2000 rpm most times.
It may surprise you something so simple will make such a difference..
Reply #6September 08, 2008, 12:24:38 pm
Yellowfox
  • 5
« Reply #6 on: September 08, 2008, 12:24:38 pm »
thanks 4 new ones will be the next step  :D
greetings
