Author Topic: gtd camshaft ....any performance ones ???  (Read 5653 times)
August 28, 2008, 05:18:27 pm
MRTANGOMAN
  • 51
« on: August 28, 2008, 05:18:27 pm »
does anyone know of a performance camshaft for a 1.6 gtd ??? :?:
Reply #1August 28, 2008, 07:09:30 pm
gigaz2
  • 626
« Reply #1 on: August 28, 2008, 07:09:30 pm »
been discussed a lot, use the search function.
I recall that the aaz was a upgrade for hydraulic motors, but don't expect a big difference like if it would on a gasser, not much clearance on a diesel.
on a gasser you have 230º and you can fit a 280 or even 300º cam before any mods for extra clearance, on a diesel you have 190º and the absolute limit is around 210º, so you can hardly feel the difference.
Reply #2August 28, 2008, 09:03:15 pm
« Reply #2 on: August 28, 2008, 09:03:15 pm »
i thought the 1.6 cam was better than the 1.9
Reply #3August 28, 2008, 09:21:45 pm
« Reply #3 on: August 28, 2008, 09:21:45 pm »
dave aka 935racer makes perf cams.  gains aren't incredible, but apparently they help reduce egt's? then you increase the fueling more  :twisted:
Reply #4August 29, 2008, 04:27:38 am
stewardc
« Reply #4 on: August 29, 2008, 04:27:38 am »
Quote from: "Trev0rbr"
The pre-91 1.6 cam is the best. I put one in my AAZ.
Reply #5August 29, 2008, 05:11:00 am
gigaz2
  • 626
« Reply #5 on: August 29, 2008, 05:11:00 am »
so.. my info was wrong :(
time to go to the shed and find what cams I have around ;)
Reply #6August 29, 2008, 06:54:33 am
MRTANGOMAN
  • 51
« Reply #6 on: August 29, 2008, 06:54:33 am »
Quote from: "gigaz2"
I did  :oops:
but got that many returns, i gave up looking after 4hrs
Thanks for the help ....
but sounds like i got the best one already...
Reply #7August 29, 2008, 12:23:21 pm
gigaz2
  • 626
« Reply #7 on: August 29, 2008, 12:23:21 pm »
I just went to the shed, two hydraulic "L" grinds :(
in the car is a AMC mechanical head with a "D" grind cam
I searched and its a 1.9NA cam, dropped in favor of the AAZ one.
bummer
Reply #8August 29, 2008, 12:33:52 pm
« Reply #8 on: August 29, 2008, 12:33:52 pm »
bummer
So what does that mean?
The 1.6 hyd cam is still the best option?
At least unless you have PP make one then your still iffy..
Reply #9August 29, 2008, 01:18:13 pm
gigaz2
  • 626
« Reply #9 on: August 29, 2008, 01:18:13 pm »
I was just stating that.
as far as I know there are 4 IDI grinds:
068109101B - mechanical  1.5 and 1.6
068109101L - hydraulic      1.6
028109101D -1Y, replaced by the aaz one
028109101G -AAZ
does anybody has data on them? I searched and found only AAZ
Reply #10September 01, 2008, 07:01:26 am
smutts
  • 720
    ClackClackClackClackClack
« Reply #10 on: September 01, 2008, 07:01:26 am »
I doubt there would be much benefits to find as valve overlap is not going to be any good, not without holes in the pistons. :roll:
Reply #11September 04, 2008, 06:18:56 pm
gigaz2
  • 626
« Reply #11 on: September 04, 2008, 06:18:56 pm »
Quote from: "stewardc"
what grind is that? the hydraulic or mechanical one?
Reply #12September 04, 2008, 06:51:43 pm
blkboostedtruck
  • 1535
« Reply #12 on: September 04, 2008, 06:51:43 pm »
X2 interesting!
stewardc can you shed your insight on this?
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #13September 04, 2008, 07:18:39 pm
AudiVWguy
« Reply #13 on: September 04, 2008, 07:18:39 pm »
Is a solid lifter cam interchangeable with a Hydraulic type?
