Author Topic: Coolant Pressure Problem  (Read 3810 times)
August 27, 2008, 10:44:08 am
JetPo
« on: August 27, 2008, 10:44:08 am »
I have a 98 TDI in my mk2 Jetta. Its fully mecanical with AAZ pump and K24 turbo. I realised that even after sitting for 12h in my driveway, there is still a lot of pressure in my coolant ( when i open my ''bol'' its squirts everywhere ...) . What could be the problem ? My temperature stais good ...
Thanks
Alex
Reply #1August 27, 2008, 11:08:47 am
« Reply #1 on: August 27, 2008, 11:08:47 am »
do this test:  release pressure from the bowl by opening the cap.   (motor should be let cool down a lot, maybe even overnight) put the cap back on, and start the motor.  let it run for about 1-2 minutes, and shut off.  now open the cap and see if it built up pressure.  if there is pressure, then you have a leak into the coolant system.
but i'm thinking that you might just have a problem with the expansion cap.  they're supposed to 'breathe' a little bit to reduce pressure.  if yours isn't, then that could explain all that pressure inside.
Reply #2August 27, 2008, 11:33:48 am
JetPo
« Reply #2 on: August 27, 2008, 11:33:48 am »
Quote from: "jtanguay"
Ok, thanks, ill do the test tonight  :D
Reply #3September 02, 2008, 03:54:02 pm
JetPo
« Reply #3 on: September 02, 2008, 03:54:02 pm »
Ok, so i did the test, let the pressure out at night, let the car stand for the night. Next morning, put some coolant back in, close cap and let the motor run for about 5min. ... there was some pressure  :oops:  So that meens i have a F!"/$%/$%ing leek  :evil:  Head gasket ? Help please  :(
Reply #4September 02, 2008, 04:24:35 pm
VW_Commuter
  • 355
« Reply #4 on: September 02, 2008, 04:24:35 pm »
If there is no oil in the coolant you can rule out the oil cooler so I would say it's the headgasket.  If you've caught it early enough it shouldn't have had a chance to do any damage to the seating surfaces on the head or block but the only way to find out is pull the head and inspect.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #5September 02, 2008, 04:26:06 pm
JetPo
« Reply #5 on: September 02, 2008, 04:26:06 pm »
Quote from: "VW_Commuter"
The head gasket was changed like 5000km ago ... ***
Reply #6September 02, 2008, 07:56:17 pm
« Reply #6 on: September 02, 2008, 07:56:17 pm »
before you start thinking the worst, maybe you just need to have the head bolts re-torqued???
Reply #7September 03, 2008, 07:52:55 am
« Reply #7 on: September 03, 2008, 07:52:55 am »
I would try this first just to see..
Reply #8September 03, 2008, 07:53:20 am
« Reply #8 on: September 03, 2008, 07:53:20 am »
Quote from: "JetPo"
The head gasket was changed like 5000km ago ... fu@*
Fixed that for ya ;)
Reply #9September 03, 2008, 12:57:15 pm
JetPo
« Reply #9 on: September 03, 2008, 12:57:15 pm »
Quote from: "zukgod1"
Quote from: "JetPo"
Thanks ;) And for the retorquing ill give it a trie
