Author Topic: gasser manifolds  (Read 7285 times)
August 26, 2008, 11:59:25 pm
danwithagolf
  • 43
gasser manifolds
« on: August 26, 2008, 11:59:25 pm »
What gasser manifolds fit on the 1.6l n/a i see tons of 1.8l gasser 8v in a auto wrecker do they fit? i would guess a 1.8 manifold would flow way better and i could pick one up for almost nothing
87 Golf n/a
Reply #1August 27, 2008, 05:00:05 am
gasser manifolds
« Reply #1 on: August 27, 2008, 05:00:05 am »
Any VW 8v manifold (intake or exhaust) should have the same bolt pattern as your car. ABA intake manifolds may be excluded from that group and I don't know about the mk4+ engines
Reply #2August 27, 2008, 07:10:38 am
shegel
  • 312
gasser manifolds
« Reply #2 on: August 27, 2008, 07:10:38 am »
i have the intake and exhaust manifold from an 86 jetta gli that iwill be installing soon. the exhaust mani is a dual dp mani and the only reason im running the gasser inake mani is cause i cannot clamp shut my n/a box with the g40 valve cover i have on there
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #3August 27, 2008, 12:02:02 pm
79rabbit4dr
gasser manifolds
« Reply #3 on: August 27, 2008, 12:02:02 pm »
I tried to post a question about this before, what are the advantages of using gasser mani's on a diesel? i've got a gas mkI (79) and a diesel mkI (81), the gasser is just being used for parts right now, is it worth swapping the parts (intake/exhaust mani's) over? What other parts would boost perf on the diesel?
does anyone have experience/examples of swapping a drivers side inlet gasser mani onto and passenger side inlet diesel mani? Pix, anyone?
Reply #4August 27, 2008, 04:23:25 pm
gasser manifolds
« Reply #4 on: August 27, 2008, 04:23:25 pm »
For intake manifolds the advantages are mainly for TDs because they have a crappy intake. On NAs it's less back pressure. Some people use both on the NAs because there is talk of clearance issues, but those can easily be ground away
Reply #5September 01, 2008, 01:35:26 pm
danwithagolf
  • 43
gasser manifolds
« Reply #5 on: September 01, 2008, 01:35:26 pm »
i guess with the n/a's with a gasser intake you would put a short ram or a cold air intake on but in the pic above could you have the exhaust mani and the intake on together on a n/a? i would like to get both on my n/a i have a short ram that would go on that intake nicely :D
87 Golf n/a
Reply #6September 11, 2008, 11:09:16 am
dieselwagen
  • 85
gasser manifolds
« Reply #6 on: September 11, 2008, 11:09:16 am »
i settled with a gasser manifold to replace the broken oem plastic air filter housing on my 1986 n/a. because none of the local wrecking yards have diesels and the dealershops were no help at all.
i tried the short ram set-up but the intake roar was too intoxicating and it grew old on me in a few days. so i added a 2.75" extension and relocated the air filter behind the passenger headlamp, and also made a heat shield.
it totally eliminated any offensive noise and i can now carry on a conversation with a passenger without shouting at each other
1986 golf 1.6
Reply #7September 11, 2008, 11:54:34 am
Dirtrag2
  • 298
gasser manifolds
« Reply #7 on: September 11, 2008, 11:54:34 am »
nice back yard engineering  :lol:
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #8September 11, 2008, 12:22:47 pm
gasser manifolds
« Reply #8 on: September 11, 2008, 12:22:47 pm »
I wonder if we could do this by flipping the exhaust manifold over and redoing the oil line, oil drain down pipe.
It would be allot of work but much better intake.
Reply #9September 11, 2008, 04:30:07 pm
Black Smokin' Diesel
  • 656
gasser manifolds
« Reply #9 on: September 11, 2008, 04:30:07 pm »
Quote from: "zukgod1"
That's how it's done on a gasser using TD turbo. Gotta flip the exhaust manifold, clock the turbo so everything is right side up, fab a downpipe, custom oil feed and drain lines, custom turbo intake... It's not that simple.
Reply #10September 11, 2008, 06:41:17 pm
gigaz2
  • 626
gasser manifolds
« Reply #10 on: September 11, 2008, 06:41:17 pm »
you mean using a TD manifold.. as a TD turbo might melt in the gasser application. EGT's are way higher.
EDIT: been studying this to see if I could use a TDI T15 to turbo my 1.4 gasser ;)
back on topic: new style turbos (TDI) already have clearance for decent intakes, I guess VW sticked to the old design for cost reasons
Reply #11September 11, 2008, 09:16:19 pm
  • 656
gasser manifolds
« Reply #11 on: September 11, 2008, 09:16:19 pm »
Quote from: "gigaz2"
I mean the entire setup minus the intake stuff. I doubt the turbo would melt, they're not as sensitve as VNTs. But the AR ratio isn't good for a gasser anyway.
Reply #12September 12, 2008, 05:40:16 am
gasser manifolds
« Reply #12 on: September 12, 2008, 05:40:16 am »
i think balancing the pressure to all 4 cylinders is a main benefit... everything else is gravy  8)  the stock TD manifold biases the two inner cyls...  but some will argue that with boost pressure, that doesn't really matter...  i think it does matter to some degree, but what do i know  :lol:
Reply #13September 12, 2008, 06:56:34 am
VW Fox
  • 23
    • http://www.vwot.org/
gasser manifolds
« Reply #13 on: September 12, 2008, 06:56:34 am »
Just put it in a longitudinal car. It makes the gasoline intake manifold upgrade easier 8)
1993 VW Passat (AAZ)
1992 VW Fox 8v (gasoline)
1980 VW Dasher 1.6TD (CY)
Reply #14September 17, 2008, 11:41:17 pm
danwithagolf
  • 43
gasser manifolds
« Reply #14 on: September 17, 2008, 11:41:17 pm »
so dieselwagen the intake mani you have what motor is that off of and what year car? i went to a auto wrecker the other day to take a look and i see tons of 8v 86-92 golfs and jettas your intake looks a bit diff tho. thanks dan
87 Golf n/a
