Author Topic: Parking Break Cable  (Read 4895 times)
August 25, 2008, 04:46:14 am
jasonsansfleece
  • 162
Parking Break Cable
« on: August 25, 2008, 04:46:14 am »
Can these strech over time?
I have an 85 Golf, the cables max adjusted, the hubs cleaned, lubed etc. No joy.
Then because of noisy wheel bearing I swapped in a complete hub/break assembly from a 91 jetta. Every thing only 4K old, checked and lubed. Still not working.
Probaly the cable but before I buy new ones, the 91Jetta has larger drums than the 85Golf. The on line parts stores show different part#s for each.
Could someone confirm wether the cables are same/different and/or which one would work,
Thanks
Guy
Reply #1August 25, 2008, 09:06:19 pm
Dakotakid
  • 1240
Parking Break Cable
« Reply #1 on: August 25, 2008, 09:06:19 pm »
Due to financial constraints ( nice way to say chronically broke) I have played this game of mix and match. However, I always exchanged the backing plate as well. Did you fail to do this???
I switched out a 92 Jetta rear brake on an '86 Golf.
I sincerely doubt that these cables stretch under any sort of normal conditions (including rust). I have had them break though.
Reply #2August 25, 2008, 11:12:02 pm
  • 2926
Parking Break Cable
« Reply #2 on: August 25, 2008, 11:12:02 pm »
I did some work on my '91 Golf rear drums awhile back.
 The e-brake cables were frayed inside the drum area, they wouldn't let the cables return so they didn't have the full range of movement.
 Side note: At the salvage yard I saw a set of new brake shoes and bearings in the trunk of an Audi 4000. Couldn't pass up the $2 deal and they looked like they would fit a Rabbit.
 They didn't fit the Rabbit but they fit the big drums on the rear of the Golf. :)
Reply #3August 26, 2008, 06:33:33 pm
jasonsansfleece
  • 162
Parking Break Cable
« Reply #3 on: August 26, 2008, 06:33:33 pm »
Backing plate swapped.
I guess I'll check in side the drums one more time and if nothings amiss then its new cables.
Reply #4August 26, 2008, 07:53:05 pm
Parking Break Cable
« Reply #4 on: August 26, 2008, 07:53:05 pm »
my driver's side cable broke on me recently... aaaaaaaargh!! but it gives me a good reason to switch over to disc brakes in the back  8)
Reply #5August 28, 2008, 08:07:24 pm
silvertdi
  • 125
Parking Break Cable
« Reply #5 on: August 28, 2008, 08:07:24 pm »
One of my cables jumped the cam at the base of the emergency brake lever, rendering the e-brake useless.  I replaced the cables, but when I started taking it apart, immediately saw what the issue was and could have saved some $$$.  Perhaps that's the problem.
