does anyone know if the sdi intake will clear a td pump?
Pages:
Topic: does anyone know if the sdi intake will clear a td pump? (Read 7213 times)
Reply #15
August 22, 2008, 02:32:51 pm
carrizog60
Reply #15 on:
August 22, 2008, 02:32:51 pm »
what are the benefits of that intake versus stock GTD :idea:
Portugal
Reply #16
August 22, 2008, 06:09:57 pm
Reply #16 on:
August 22, 2008, 06:09:57 pm »
this one is completely heterosexual, unlike the stock vw one
Reply #17
August 22, 2008, 06:19:04 pm
flapjack
Reply #17 on:
August 22, 2008, 06:19:04 pm »
Looks like you may be able to flip an ABA intake manifold around.
signature
Reply #18
August 23, 2008, 11:01:27 am
Reply #18 on:
August 23, 2008, 11:01:27 am »
yeah it does, that would kind of be neat if an aba intake bolted to it.that would really confuse people that looked in that engine bay haha. but if the plastic *** doesn't fit, i'll make it fit
Reply #19
August 24, 2008, 10:28:21 pm
danwithagolf
User+
Reply #19 on:
August 24, 2008, 10:28:21 pm »
i want one for my n/a where would you find one? what motor is that off of?
87 Golf n/a
Reply #20
September 02, 2008, 02:09:24 pm
Reply #20 on:
September 02, 2008, 02:09:24 pm »
doesn't look promising
Reply #21
September 02, 2008, 02:26:27 pm
blkboostedtruck
Reply #21 on:
September 02, 2008, 02:26:27 pm »
have a riser made so it lifts the plastic intake up an inch or so?
you can make that work! just use some creativity !
you could ditch the studs and drill and tap the head for the older style valve cover?
maybe a heat gun to reform the plastic to make some clearance for the pump?
Duane
injector rebuilds call 414-840-1395 for faster service not on line much!
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
3 jettas '82' '04 '14TDI
Reply #22
September 02, 2008, 03:47:49 pm
Reply #22 on:
September 02, 2008, 03:47:49 pm »
yeah i'm not worried about the valve cover at all, i have plenty of 1.6 valve covers i could stick on. it's the pump clearance i am worried about. a 1 inch riser may do the trick though, i'll have to wait until i have my td back though. ill measure on my dads car tho and see what all it will take.
Reply #23
September 02, 2008, 03:53:35 pm
Reply #23 on:
September 02, 2008, 03:53:35 pm »
also i think the picture makes the clearance of the studs look worse since i don't have any bolts holding the manifold to the head.
Reply #24
June 22, 2009, 04:10:04 pm
Re: does anyone know if the sdi intake will clear a td pump?
Reply #24 on:
June 22, 2009, 04:10:04 pm »
so since i have the head off my td i tried fitting the head and manifolding, it hits the pump alot, theres no way it will fit on a car with a td pump installed, you would need maybe a 3 inch spacer and then theres no way the hood would ever shut. with an na pump it may work with a smaller spacer, maybe 1 inch or so, but it's not very promising. so sdi intakes for us idi people has been shot down, except maybe with an na pump, does anyone want to buy an sdi intake manifold?
Reply #25
June 22, 2009, 06:23:31 pm
Reply #25 on:
June 22, 2009, 06:23:31 pm »
I do. How many clams?
IM me
Reply #26
June 22, 2009, 07:29:30 pm
Reply #26 on:
June 22, 2009, 07:29:30 pm »
even then i really question it, maybe a mk2 or mk3 would be a better fit
Pages:
