Author Topic: FS 1.6 diesel parts garage sale...  (Read 4418 times)
August 17, 2008, 08:20:39 am
houseofdiesel
  • 210
« on: August 17, 2008, 08:20:39 am »
I am cleaning up the garage, found the following that I no longer need
-1.6 ME code cylinder head, hydraulic lifters, non turbo, complete and decent, very minor cracks between valves, no other issues $100
-1.6 ME diesel block with oil pan, pistons, rods, crank, intermediate shaft etc ring ridge very minor good looking engine $100
-transmission bracket that runs front to rear below battery area $5
-trans mounts $5
-front motor mount, rubber style non hyd $5
-new headgasket 1 hole hydraulic $30
-inner upper timing belt cover (metal) $2
-outer upper timing belt cover (plastic) X3 $2
-dipstick tube $2
-air boxes for non turbo $5
-intake manifolds non turbo $5
-cam savers (black plastic under valve cover) $5
-valve covers $5
-alternator bracket $5 (one that covers waterpump and mounts accessories)
-rear engine mount bracket for block (alloy) $5
Located near Ottawa, Ontario, I am coming to Toronto this week
Greg
Reply #1August 17, 2008, 12:50:34 pm
« Reply #1 on: August 17, 2008, 12:50:34 pm »
the dipstick tube....do you have just the dipstick? I have a tube with no stick? let me know thanks Lucas ><>
Reply #2August 17, 2008, 10:17:01 pm
53 willys
« Reply #2 on: August 17, 2008, 10:17:01 pm »
I need the dip stick tube!!!!
if theman53 does not want the tube I will take it!!!
I will also take the upper plastic t-belt cover...if it is in good shape??(no belt/pulley rub holes?)
also are the motor mounts in good shape? are they oil soaked??
let me know
Reply #3August 18, 2008, 01:53:37 am
mtnbob
  • 738
« Reply #3 on: August 18, 2008, 01:53:37 am »
I need an Airbox but also need the hose from the airbox to the filter. Any chance you have one of those?
96 Subaru Outback Wagon
Reply #4August 18, 2008, 02:51:39 pm
houseofdiesel
  • 210
« Reply #4 on: August 18, 2008, 02:51:39 pm »
I have only the dipstick tube, I might have a dipstick around also but I have not noticed one lately.
All plastic parts are in good shape, the pulley rubbed ones met the trash can long ago!
Motor mounts are perfect, anything less was trashed. Not oil soaked, my diesels are not leakers...
I don't have any of the air intake hoses from the fender to the airbox, apparently a truck service center is the place to go intercooler hose or coolant hose will work from them
