Author Topic: TDC cam to crank  (Read 2578 times)
August 16, 2008, 03:24:37 pm
  • 3468
    • McScrubbins Body Wash
TDC cam to crank
« on: August 16, 2008, 03:24:37 pm »
I lost all my papers a while back and im missing just simple key info like lobe positions for TDC
i usually keep the pullys locked in position but i want to re-do the timing with the cam to the crank. I know to use the flywheel for the crank but where should the lobes be? Can the cam be 180 degrees out? or can i just lock the cam on the right hand side at either one of the 180 degree positions.
Thanks,
Ed.
Reply #1August 16, 2008, 03:38:18 pm
Luckypabst
  • 502
TDC cam to crank
« Reply #1 on: August 16, 2008, 03:38:18 pm »
The slot at the flywheel end is offset so your cam lock will only fit with the cam at TDC #1.
Chris
'82 TD Westy
'81 NA Caddy
Reply #2August 16, 2008, 03:39:33 pm
  • 3468
TDC cam to crank
« Reply #2 on: August 16, 2008, 03:39:33 pm »
OHhhhhhhhhh!!! That's right!!! i remember now
Duhhhh im a moron
thanks mate
Reply #3August 16, 2008, 03:40:05 pm
jackbombay
  • 599
Re: TDC cam to crank
« Reply #3 on: August 16, 2008, 03:40:05 pm »
Quote from: "Smokey Eddy"
  The lobes for #1 should both be "up" and you need to use a locking plate, you can't eyeball it.
Reply #4August 17, 2008, 11:47:46 am
  • 3468
TDC cam to crank
« Reply #4 on: August 17, 2008, 11:47:46 am »
i used a file :D
an easy way to think  of it that makes sense is that none of the valves are open.
Thanks guys,
Ed.
