Cam seal=groves worn into my cam=??
Topic: Cam seal=groves worn into my cam=?? (Read 2418 times)
August 15, 2008, 04:33:51 pm
53 willys
August 15, 2008, 04:33:51 pm »
yeah I am taking my head apart today and I see that the cam seal has worn two diffreant groves into the cam...is this ok? normal? if not whats the best way to fix it??
can a machine shop fix the issue?? or would I need to buy a new cam or?
thanks
August 15, 2008, 04:39:20 pm
August 15, 2008, 04:39:20 pm »
Depends on if it's leaking or not. If not, I'd just fit a new seal. If it is, a machine shop can pot a speedy sleeve on.
August 15, 2008, 06:00:15 pm
53 willys
August 15, 2008, 06:00:15 pm »
yeah I dont really know if it was leaking???
when I got this engine it looked like everything had been leaking on it!! lol
...I guess I will just ask the machine shop what they think...
August 16, 2008, 08:15:18 pm
August 16, 2008, 08:15:18 pm »
Worst case I probably have another cam for ya.
August 17, 2008, 06:40:02 am
53 willys
August 17, 2008, 06:40:02 am »
Quote from: "zukgod1"
thanks Dan I will just put it together for now and see if it does leak...
thanks to you and this forum for all the help and advice you give.
August 17, 2008, 11:42:07 am
August 17, 2008, 11:42:07 am »
If you got it and it's filthy as hell it probably does leak from the cam because its the highest and most likely point to leak copious amounts of oil. I tried to reuse a broken cork gasket once with heaps of RTV it sorta worked but it still made a huge mess. Get a rubber gasket if you can, i recomend it!
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
