Author Topic: longer 5th?  (Read 6172 times)
May 30, 2005, 04:25:39 pm
sethyboy85
  • 284
longer 5th?
« on: May 30, 2005, 04:25:39 pm »
this gear or any of the other ones this person sells work in my 84 diesel right? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33733&item=2476923131&rd=1&ssPageName=WD1V
I would just have to go out and buy the gasket, tool and c-clip and have fun one saturday right?
Most of my driving in 5th gear is on the highway after I have accelerated to 70mph then I cruise at about 75mph so a longer 5th is much needed for me as 80mph would be a more optimum speed for me to stay with traffic.
84 TD in question
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #1May 30, 2005, 05:34:25 pm
Northern RD
  • 167
longer 5th?
« Reply #1 on: May 30, 2005, 05:34:25 pm »
Somebody back me up on this one but didn`t Autotech have such a kit at one time???? :?
Reply #2May 30, 2005, 06:04:20 pm
sethyboy85
  • 284
longer 5th?
« Reply #2 on: May 30, 2005, 06:04:20 pm »
yes $240
I am not paying a 1/3 for a 5th gear of what I paid for the car....
Reply #3May 31, 2005, 12:33:17 pm
veeman
  • 421
longer 5th?
« Reply #3 on: May 31, 2005, 12:33:17 pm »
FWIW, I put a longer fifth gear in one of my rabbit GTI's.  The fifth in my 2H was practically unbearable for highway driving.
We used a .75 gear out of another gearbox (longer ratio) and with a friend's help, we got it done in less than an evening.  Not very hard, but you do need the tool (I believe it's the same as the triple-square head bolt socket on most VW's).  I remember my friend used a torch to add heat at some point to help the process along.
The new fifth is great!  Vast improvement for longer trips.
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
Reply #4May 31, 2005, 11:19:48 pm
racer_x
  • 123
Re: longer 5th?
« Reply #4 on: May 31, 2005, 11:19:48 pm »
Your 1984 TD should have a 0.711:1 fifth gear set in it already. That car should have either an FN or a 7A transmission. Either of those already have the tallest 5th gear available (0.711:1).
Check the code on the bell housing of your transmission to see what you have now. There's a 2 or 3 character code and a 5 digit number. If you post the whole code, I can tell you which 5th gear set you have now.
That's not a really good price on that gear set either. I'd get you a used set for at least $30 cheaper than that (and I'd still make a few dollars on it at $60 for the set).
And you'll need a new 5th gear housing gasket, a new 5th gear retaining bolt, a new 5th gear shift fork locking plate and a new 5th gear circlip for the pinion shaft. The bolt is expen$ive (like $45-$55 last time I checked). The bolt is a highly stressed fastener and is a "use once" bolt. The shoulder of the bolt can fail if you re-use it, and with the helical cut gears, if the bolt fails, the gear shoots out the end of the transmission.
You can get by without the special tool for the shift fork, just use vice grips on the outside of the shift fork tube (very carefully).
Reply #5June 02, 2005, 09:01:48 pm
addautomotive
longer 5th?
« Reply #5 on: June 02, 2005, 09:01:48 pm »
I've done the 5th gear swap 3 times now, and can do it in 3-4 hrs. Instead of the special tool, I ground the end of an 11 mm socket so it had 2 tabs that fit the selector tube.
Reply #6June 02, 2005, 09:04:00 pm
addautomotive
longer 5th?
« Reply #6 on: June 02, 2005, 09:04:00 pm »
Reply #7May 22, 2006, 10:17:06 pm
ODwyerPW
  • 103
    • http://www.Espanglish.com.mx
longer 5th?
« Reply #7 on: May 22, 2006, 10:17:06 pm »
The Ebay aution he was showing was for the R&P, Final Drive...not the 5th gear.  He does have the lowest 5th possible, but he may not have the 3.67 final drive; probably has the 3.89 found in the FN/7A.  So by using this Final Drive off of Ebay, he'd be even taller.
I'd like to find those 3.42 (Dodge Omni) or 3.29 (some 4S models?) R&P and install that with the .71 5th (FN/7A.  That would be tall.  Would be the closest 020 folks could come to the 3.156 X .681 combo that the 02A folks are doing.
83 Rabbit LS Turbo Diesel
Reply #8May 23, 2006, 09:28:33 am
QuickTD
  • 1156
longer 5th?
« Reply #8 on: May 23, 2006, 09:28:33 am »
The unfortunate thing about the 4 speed final drive is that it can only be used in a 4 speed. The pinion is an integral part of the transmission countershaft. On a 4 speed the countershaft does not have the extension to mount 5th gear.
Reply #9May 23, 2006, 10:40:53 am
bhtooefr
  • 305
    • http://my.opera.com/bhtooefr
longer 5th?
« Reply #9 on: May 23, 2006, 10:40:53 am »
Why not just go to an 02A and avoid the whole 020 shift linkage issue altogether? ;)
Anyway... make sure you guys have the power to back it up... my 3.94 R&P and (depending on who you ask... Bentley says .745, Scirocco.org says .89, and my owner's manual and my ear-tach agree with .89) 5th are too tall for my 52 horses, when I need to climb a hill at speed or pass. :?
Assuming a .89 5th, I could use like a .85 6th, and a .91 5th... I'd still have to downshift to pass, but it'd be lower RPMs than a 1.03...
1986 Volkswagen Golf | 1.6L NA diesel | 5spd manual | Deep Cosmic Blue (LE5C) | aack, it's a parts car, now, too!
1992 Mazda Miata | 1.6L DOHC gasser | 5spd manual | Classic Red (SU)
Reply #10May 28, 2006, 07:20:03 am
therabbittree
  • 299
longer 5th?
« Reply #10 on: May 28, 2006, 07:20:03 am »
cause teh 020a shifts like crap and unless you use the cable throw out from older eurovan you need hydr clutch, and shift cables.. etc etc.. you can drive 020 with out using the clutch and its is nice..thgey aren't as strong ..but as long as you don't dump teh cluthc at a start and slowy apply the power you should be good. a 2.0L gasser with a cam would easyily pull my 367 and .71 gear combo so abuilt 1.6L TD or a tdi m would really workwell im swapping in a 367 r& p into my 7a td box with a quaife in it ..i hope that works well
later
Deo
Reply #11May 28, 2006, 12:32:38 pm
sethyboy85
  • 284
longer 5th?
« Reply #11 on: May 28, 2006, 12:32:38 pm »
thats what I am slowly working on, I have a .71 5th need a case and 3.67 and I have the rest of the gears/syncros and crap from a FF tranny.
Reply #12November 02, 2006, 03:47:31 pm
VWCaddy
  • 85
    • VW Caddy Page
longer 5th?
« Reply #12 on: November 02, 2006, 03:47:31 pm »
Quote from: therabbittree
later
Deo
Easy to cure the sloppy 020 shift linkage:
- http://www.4crawler.com/Diesel/ForSale/ShiftLinkage.shtml
I'm just getting done installing a 3.67 ring/pinion gear set in my FN transaxle,  so coupled with a 0.71:1 5th gear, should drop the highway revs to about 2500 @ 65.
'82 VW pickup, 1.9D engine, Missing LinkZ shift linkage
Fixmyvw.com
