Author Topic: 1.6 TD / AAZ Injector pump question...  (Read 2081 times)
August 15, 2008, 06:34:45 am
MrRoast
  • 2
« on: August 15, 2008, 06:34:45 am »
I've got an AAZ and I'm planning to replace the stock pump with a pump from a 1.6 TD to increase performance. My question is this - is the injector pump from a mk2 GTD (JK/SB engine code) the same as the pump used in similar age 1.6 TD Passats?
Looking on ETKA it shows that the Passat used the SB engine but gives 2 different part numbers for pumps used on the the SB -
B 068 130 081 R
and
B 068 130 110 BX
are these pumps the same in terms of performance?
Any help would be great!
Reply #1August 15, 2008, 06:56:15 am
blkboostedtruck
  • 1535
« Reply #1 on: August 15, 2008, 06:56:15 am »
you will have problems fitting the 1.6TD punp in place of the 1.9 the brackets are different between the 2 you would have to go with the 1.6 bracket as well!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2August 15, 2008, 01:21:55 pm
regcheeseman
  • 714
« Reply #2 on: August 15, 2008, 01:21:55 pm »
powers quoted the same for the two - same pump - the passat ones are nomally way more common and cheaper because everyone HAS to have the GTD golf one
