Author Topic: 1.6 TD / AAZ Injector pump question...  (Read 1870 times)
August 15, 2008, 06:34:21 am
MrRoast
  • 2
« on: August 15, 2008, 06:34:21 am »
I've got an AAZ and I'm planning to replace the stock pump with a pump from a 1.6 TD to increase performance. My question is this - is the injector pump from a mk2 GTD (JK/SB engine code) the same as the pump used in similar age 1.6 TD Passats?
Looking on ETKA it shows that the Passat used the SB engine but gives 2 different part numbers for pumps used on the the SB -
B 068 130 081 R
and
B 068 130 110 BX
are these pumps the same in terms of performance?
Any help would be great!
