Like everything else I am probably overthinking and wrong, but I hope I am a little more clear on what I meant earlier is that ARP probably shouldn't say just do what the stock bolts call for. Lucas
Actually, maybe i will sit down with a calculator tommrow and just figure it out. anybody have the thread pitch of the arp studs? are they the same as the block threads?
Comparing apples to apples, if the thread pitch is the same on the arp vs the raceware. the torque values should be the same.
Quote from: "Jet A" Comparing apples to apples, if the thread pitch is the same on the arp vs the raceware. the torque values should be the same.Yes, if the friction of the threads and washer are the same. It is not, so you have different torque values between Raceware and ARP.
