Author Topic: Converting a new beetle to mechanical steering?  (Read 5926 times)
August 12, 2008, 12:58:37 pm
« on: August 12, 2008, 12:58:37 pm »
Just wondering if anyone knows a setup that will 'bolt on' to a new beetle to make it non power steering as i don't want to install a pump on the motor...  my other option is to buy a electric hydraulic motor...
thanks
Reply #1August 12, 2008, 02:57:41 pm
gigaz2
  • 626
« Reply #1 on: August 12, 2008, 02:57:41 pm »
I've been searching on etka, and the new beetle is basically a pretty golf mk4, and that one doesn't have the manual steering option as well.
but, me and a friend have put a mk4 steering on a mk3 golf shell, so you could do the opposite, not bolt on, but almost.
you would need a mk2 steering box (also equips mk3) and non power steering mk3 rods. (thats my mk2 setup BTW ;) )
the mk2 rods are good to try it out, but you would run out of threads when aligning (one wheel would point left and the other right)
Reply #2August 12, 2008, 03:48:51 pm
gigaz2
  • 626
« Reply #2 on: August 12, 2008, 03:48:51 pm »
here is how i looks with mk2 rods with just one or two threads:
in that picture it already had the same width as a mk3
Reply #3August 13, 2008, 06:34:39 am
« Reply #3 on: August 13, 2008, 06:34:39 am »
i wonder if i use the power steering rods but trim them a bit?
Reply #4August 13, 2008, 07:28:18 am
gigaz2
  • 626
« Reply #4 on: August 13, 2008, 07:28:18 am »
no, they won´t fit the non power steering box
EDIT:
the non PS rods end like a bolt, and the PS ones like a nut.
an adapter could be machined, but I bought my rods for about 12€ each, so its not worth while the effort.
I remember that there were differences in the way the steering column attaches to the box as well as its placement.
its doable, but I would search for the electric pump solution first.
Reply #5August 14, 2008, 02:18:42 pm
« Reply #5 on: August 14, 2008, 02:18:42 pm »
http://cgi.ebay.com/ebaymotors/Hydraulic-power-steering-pump-Hot-rod-electric-Custom_W0QQcmdZViewItemQQ_trkparmsZ72Q3a552Q7c39Q3a1Q7c66Q3a2Q7c65Q3a12Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem250280300891QQitemZ250280300891QQtimeoutZ1218748778293
looks like i'm buying this... having power steering even if the motor is off me likes!  not that these cars are that hard to steer...  :roll: someone MUST make a rally conversion or something!!! but i'd be into the $1000 kit range then, and noooooo thanks!  :lol: the guy has a good rating and new pumps are in the 600-700 dollar range  :shock: so hopefully i don't get a dud...
i'll let everyone know how it works out once i get it running (might be a while  :()  it's pretty simple though.  just give it a nice juicy big wire, then a 12v keyed power, and voila!  builds up a bit of pressure, and when you turn the steering wheel it kicks on and cycles off when driving straight. 1-2mpg's???  8)
Reply #6August 14, 2008, 02:33:58 pm
gigaz2
  • 626
« Reply #6 on: August 14, 2008, 02:33:58 pm »
600bucks??
Renault Clio diesel have electric hydraulic pressure pumps as the normal one wouldn't fit on the crowded engine compartment.
a friend bought a used one for 140€, Ill bet you have similar pumps around there ;)
Reply #7August 14, 2008, 03:53:28 pm
« Reply #7 on: August 14, 2008, 03:53:28 pm »
Quote from: "gigaz2"
600bucks??
actually no.. apparently you guys are what we call... 'special'  :lol: was that 140€ for a new pump? i'm talking $600 for new from the dealer...
Reply #8August 14, 2008, 05:45:03 pm
gigaz2
  • 626
« Reply #8 on: August 14, 2008, 05:45:03 pm »
no, second hand, a new one would cost about that much (600)
not so special, still looking for European companies to do coatings on pistons, powdercoating, and EDM... :(
Reply #9August 22, 2008, 05:12:02 am
« Reply #9 on: August 22, 2008, 05:12:02 am »
well got the pump.  yay no customs charges!  now i just need to get it installed  :roll:  :lol:
Reply #10October 02, 2008, 01:47:08 pm
shortysclimbin
  • 138
    • Performance Diesel Engineering
« Reply #10 on: October 02, 2008, 01:47:08 pm »
My mk2 has a mk3 rack and control arms (wider) with a mk2 non power steering unit in it. I do need longer tie rods to pull it all together though. It was a really easy fit fwi!  If someone has the oem numbers for those rods that would be great since I am in europe right now.
As far as the mk4 with a electro powersteering. Go with a 35mph cutoff to go all manual... You dont need it higher than that and might want more power lower than that. and I agree 1-2mpg could be saved with no ac add another 1mpg! Next thing to go for me is the coolant pump!
Reply #11October 08, 2008, 09:57:04 pm
« Reply #11 on: October 08, 2008, 09:57:04 pm »
Quote from: "shortysclimbin"
electric coolant pump?  either that or a clutched coolant pump would be pretty 'cool'  :lol: or not...  :wink: for those really cold starts where the coolant might actually cool the pre-chambers and the head, so the motor doesn't combust the fuel as well...
Reply #12October 27, 2008, 08:38:04 am
molgrips
  • 134
« Reply #12 on: October 27, 2008, 08:38:04 am »
Seat cars (another European VAG brand, for the unfamiliar - lovely cars) have electric power steering.
You might have some luck with this
http://www.bba-reman.com/content.aspx?content=seat_ibiza_electric_hydraulic_power_steering_pump
Since it's a VAG part :)
1994 Passat 1.9 TD Estate, 180k miles, running on veg oil
Reply #13October 27, 2008, 11:04:15 am
« Reply #13 on: October 27, 2008, 11:04:15 am »
yea thanks, but still not cheap!  :lol: that is close to 700 canadian dollars!  i've spent 600 on another one that should work fine.
i really wish we had those nice cars here, then parts like this would be at the wreckers for cheaper...
