Author Topic: 1.6L TD in a Dodge Caravan  (Read 234728 times)
Reply #480May 06, 2010, 09:50:07 am
arb
Re: 1.6L TD in a Dodge Caravan
« Reply #480 on: May 06, 2010, 09:50:07 am »
Still searching for a good head... The post I had asking if anyone had done business with Klaus with his $555 new hydro 12mm heads was removed. He did not want anyone outside his town looking for heads from him. Oh well. Partsplaceine will sell one for $44 more, with warranty.
I even asked Prothe what he wants for a complete head, but he must be too busy to answer.
Would like to drop the dine tomorrow so I'll be driving again asap.
Reply #481May 06, 2010, 10:50:33 am
« Reply #481 on: May 06, 2010, 10:50:33 am »
smokey eddy had good luck with prothe's aaz head. If you would be doing your own porting, i wouldnt worry to much about casting marks as you could remove them yourself eh?
Would you consider a 1.6/1.9!? LOL
Reply #482May 06, 2010, 11:45:59 am
arb
« Reply #482 on: May 06, 2010, 11:45:59 am »
How true.. so the casting marks were the complaint with his heads ?
Reply #483May 06, 2010, 11:47:41 am
« Reply #483 on: May 06, 2010, 11:47:41 am »
I believe so, that and many think because its coming from china.. that its going to be of lesser quality then a German head... Why? Chinese/Japanese engines take some abuse from there users as well dont they? ;)
Reply #484May 06, 2010, 11:52:35 am
arb
« Reply #484 on: May 06, 2010, 11:52:35 am »
My only concern with a China IDI head is what alloy they used for the prechambers. I can see them using just steel and them not lasting 30 years.
Reply #485May 06, 2010, 11:53:55 am
« Reply #485 on: May 06, 2010, 11:53:55 am »
ahhh. there is a good point. Grab a few from a known good source and put them in ??? lol.
I think after the cheap head, precups, and your time porting.. your still cheaper then a German head no? i really have no idea though.
Reply #486May 06, 2010, 11:59:14 am
arb
« Reply #486 on: May 06, 2010, 11:59:14 am »
I'm leaning toward German if I can find one with no crack ( I know they can run years with cracks between the valves, but why not start clean when my wife says to fix in once and for all ?) if not, I think I can trust the Topline heads cast in Brazil and the rest assembled in Florida. VW setup alot of manufacturing in Brazil.
Reply #487May 06, 2010, 12:01:56 pm
« Reply #487 on: May 06, 2010, 12:01:56 pm »
I'd suggest prothe only as a last resort to get it back on the road for under 5 years. ;)
Good luck with this (hopefully final) fix :P
Reply #488May 06, 2010, 12:12:16 pm
arb
« Reply #488 on: May 06, 2010, 12:12:16 pm »
Just found I can get a complete turbo hydro head ( Topline ) for $587 shipping including from westendengineparts.com ..... looking like my best bet as there don't appear to be any used ones w/o cracks.
Reply #489May 06, 2010, 03:07:56 pm
BlueMule
  • 51
« Reply #489 on: May 06, 2010, 03:07:56 pm »
Arb, I have an "Alabama Cylinder Head" reman head on the BlueMule, it has 100 + k miles on it. It was reasonably priced and of good quality. The cracks between the valves were welded up, and the prechambers were replaced. Not all of the valves were replaced, but as long as the margins are good there would be no need to replace them. It was flat and again I had no problems at all. Anyway food for thought. I had to call and give them the casting # off of the head, as they do not list this particular head on the website.
https://www.alabamacylinderhead.com/productlist.php
BlueMule
A.S.E. Master Since 1986
Nissan Master Since 1995
Auto Tech Since 1975
Totally Ignorant When It Comes To MY
'86 Golf TD
Reply #490May 06, 2010, 03:11:44 pm
« Reply #490 on: May 06, 2010, 03:11:44 pm »
If they are custom making these I wonder if they would do it in Ductile or some other iron :D
Reply #491May 06, 2010, 04:19:36 pm
arb
« Reply #491 on: May 06, 2010, 04:19:36 pm »
I was so focused on finding a 1.6 head new, I missed this !!!  Yes, as long as I'm replacing the head, I should keep my option wide open :-) Time to dig deeper.
Reply #492May 06, 2010, 08:01:44 pm
« Reply #492 on: May 06, 2010, 08:01:44 pm »
All of your 1.6 head stuff will swap over. Eddy bought a bare AAZ head off prothe and swapped over all the 1.6 stuff from the best of my knowledge anyhow. lol
It would be BEAST. Give you some extra ponies while your in there anyway eh?
Reply #493May 07, 2010, 09:36:53 am
mattbondy
  • 38
« Reply #493 on: May 07, 2010, 09:36:53 am »
Are you fairly close to the USA/Canada border?
You could try these guys: Heinz garage 205 Wyandotte Street East, Windsor, ON N9A 3H5‎ - (519) 256-8161‎
http://www.heinzgarage.net/about_us.html
They are very close to the Detroit/Windsor tunnel. Its a VW, Porsche, Audi, & Mercedes garage.
I bought a german head they had sitting around a few years back ($200, no cracks between the valves, intake and exhaust manifolds included). At the time they were just looking to get rid of all the old IDI parts they had sitting around.
Another local shop with a bunch of parts cars sitting around:
All Cars 2580 Manning Road, Tecumseh, ON N0R 1K0‎ - (519) 979-4721‎
These guys are further from the border (half an hour at the most). However, I wouldnt expect any great deals.
I dont know where my Jetta with the 'new' head ended up. However, I was beating the snot out of towards the end so the head is quite possibly little better than scrap.
Reply #494May 07, 2010, 09:56:00 am
arb
« Reply #494 on: May 07, 2010, 09:56:00 am »
Thanks Matt - yes, I can almost see Windsor from our parking lot ;-)  I'll check them out... They don't have a used one, and they quoted me  $1,500 CAD for a new head...
I just pulled the trigger on a new AAZ head loaded from Prothe, including new 155 bar injectors with mercedes nozzles. Hopefully I'l have good luck like Smokey Eddie when he got a head from Pete. The goal is to get back on the road asap. After I pull the head this weekend, I'll pull the trans and see if I have a 200 or 210mm clutch. I know its at the edge of its service life, so this is a good time to swap it. Out the door with a HG and 12mm bolts, new cam baffle, head, 4 injectors, and shipping $596.20 USD.
« Last Edit: May 07, 2010, 09:59:35 am by arb »
