Author Topic: Would this turbo work???????  (Read 3307 times)
May 26, 2005, 02:26:52 pm
Justin
  • 455
« on: May 26, 2005, 02:26:52 pm »
what do you guys think of this turbo to put on a 1.6 Diesel? its an IHI turbo serial # RHF4, and here is the link to the specs for it, I can probably pick it up for free and I would build the 1.6 to compliment the turbo.
http://www.ihi-turbo.com/turbo_RHE-RHF.htm
Let me know what you think, thanks guys
later
justin
www.archeryprostaffmi.com
Reply #1May 27, 2005, 07:28:32 am
Justin
  • 455
« Reply #1 on: May 27, 2005, 07:28:32 am »
bump
Reply #2May 27, 2005, 08:59:03 am
DVST8R
  • 535
« Reply #2 on: May 27, 2005, 08:59:03 am »
At first I thought it was light in the flow department, and then I realised that it was in m3/min not lbs/min. After a little looking and calculating I think that for a free turbo I would run it. Not a huge PR, but good flow, being that it is ball bearing it should spool up well too.
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #3May 29, 2005, 03:02:53 pm
Justin
  • 455
« Reply #3 on: May 29, 2005, 03:02:53 pm »
DVST8R,
What Calculations did you use to figure out that this turbo would probably do the trick,  and what is PR?
Thanks for your help
Later
Justin
Reply #4May 29, 2005, 10:30:10 pm
DVST8R
  • 535
« Reply #4 on: May 29, 2005, 10:30:10 pm »
maximum PR is 2.7 as stated by the web site you gave. The calculation I did was change m3/min to lbs/min. Then I took the map and compared it to the stock kkk map, and the stock garret map (well a close one anyway) and extraplated from there. Also if you look on the website that you listed it has a recomended diesel HP rating range of 46-130. Fine for most 1.6TD's. If you need any more turbo info I would highly recomend the books "maximum boost" by corky bell, and "turbochargers" by hugh macinnes. Chapters has a 30% off sale on right now and both of these books qualify. :wink:
