Author Topic: Urgent help! Pump, am I missing something?  (Read 4204 times)
August 08, 2008, 01:41:45 am
ThomZe
  • 57
« on: August 08, 2008, 01:41:45 am »
The shroomy head where the boost pin goes in is EMPTY? and my pin dosent fit.. There's no needle pressing out?
What the ..... is that?
Is it a pump from a non turbo?
also, the hole in the head, where the vaccum tube is attatched, is blocked out, no threading what so ever..
BMW E36 320i Automatic
Reply #1August 08, 2008, 03:18:36 am
gigaz2
  • 626
« Reply #1 on: August 08, 2008, 03:18:36 am »
hehe, I'll get the popcorns :D this is going to be fun..
I've never seen one empty, it can be the LDA or the ADA type, but always has a diaphragm inside :S
Reply #2August 08, 2008, 03:24:46 am
dillenger1
  • 777
« Reply #2 on: August 08, 2008, 03:24:46 am »
hmmm.mysterious. :) sounds like you got yerself a "eco"pump(turbo,but no additional fueling)
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #3August 08, 2008, 03:54:23 am
gigaz2
  • 626
« Reply #3 on: August 08, 2008, 03:54:23 am »
ahhh yeah, the ECO one, that makes sense, it looks like what was described.
Reply #4August 08, 2008, 04:37:09 am
foxracer1
  • 991
« Reply #4 on: August 08, 2008, 04:37:09 am »
The ECO doesn't have the diapham housing. It looks like a regular N/A pump.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #5August 08, 2008, 05:38:15 am
gigaz2
  • 626
« Reply #5 on: August 08, 2008, 05:38:15 am »
the one I've seen on the Portuguese forum was like described, the pin wouldn't go in because the housing wasn't made to accept a pin, it looks like the "spaceship" but its empty
Reply #6August 08, 2008, 07:10:27 am
« Reply #6 on: August 08, 2008, 07:10:27 am »
Can you post a pic Tom?
Nothing under the cap as in there is no diaphram or boost pin is that correct?
Reply #7August 08, 2008, 07:54:06 pm
ThomZe
  • 57
well
« Reply #7 on: August 08, 2008, 07:54:06 pm »
spoke with a bosch technician, the head where the pin should be, was completely empty, not even threading to do anything, hell, I had to swap the whole top from my old pump :(
Some td's with smaller turbos don't need the smokepin, so they simply don't have it.. anyway the car is a little quicker now, but still lacks alot of life in the higher end, a little step forward.. but still looong way to go to get it running normal..
I'm running on Garrett T25 turbo"stock", TDI 1Z/AHU engine, stock tdi nozzles, 1.9AAZ Pump w. 10mm rotor, tdi plate.. slightly modded boost pin.. fuel enrichmentscrew is a bit in, but it's not doing more black smoke than many non tuned diesel cars..
But still there's a great lack of power to it, :\ but hell, I think I'll just have to take it to bosch service, it'll almost cost, what the cars worth, but I just don't want to get rid of it
Reply #8August 09, 2008, 06:07:33 am
dillenger1
  • 777
« Reply #8 on: August 09, 2008, 06:07:33 am »
If your sending it to a bosch shop,you should just talk to giles then.It will be 3 or 4 hundred more dollars depending on the shop prices.I didnt think a regualr td ever came "without'a boost pin.that doesnt make sense.
Reply #9August 09, 2008, 06:14:02 am
gigaz2
  • 626
Re: well
« Reply #9 on: August 09, 2008, 06:14:02 am »
Quote from: "ThomZe"
as you were told.. its an ECO pump, its ECO because it doesn't enrich under boost, less diesel, less power, more MPG :D
so, its NOT a TD pump, even the timing was designed to cut power down low because of emissions...
basically.. you were had
