Author Topic: Diesel Timing Tool  (Read 5160 times)
August 03, 2008, 08:26:39 am
kylebeck_34
  • 1
Diesel Timing Tool
« on: August 03, 2008, 08:26:39 am »
im looking for the tool to set the timing on my injector pump. does anyone know where to find it. thanks
Reply #1August 03, 2008, 09:11:09 am
foxracer1
  • 991
Diesel Timing Tool
« Reply #1 on: August 03, 2008, 09:11:09 am »
Call the Parts Place (248) 373-5950 its in auburn hills michigan. They have a website but it's not always current. www.partsplaceinc.com
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #2August 03, 2008, 09:26:11 am
Reply #3August 04, 2008, 05:41:18 am
FWD.MOTION
  • 170
Diesel Timing Tool
« Reply #3 on: August 04, 2008, 05:41:18 am »
thanks for the link, I just ordered that one at the top of your list!
Now I can time out my pumps and make them run correctly
thanks for your help
base
BASELYNE
Reply #4August 05, 2008, 05:14:52 pm
Choppercat
  • 42
Diesel Timing Tool
« Reply #4 on: August 05, 2008, 05:14:52 pm »
I personnally chose that one too and is suppose to show up this week :wink:
Can't wait...
DIESEL SMOKE IS ADDICTIVE!!!
'93 AAZ Golf
'99 Jeep TJ
Project: '51 Willy's CJ-3A AAZ
Reply #5August 07, 2008, 05:29:55 pm
79rabbit4dr
Diesel Timing Tool
« Reply #5 on: August 07, 2008, 05:29:55 pm »
I got that one too, showed up really quick considering it came from Germany. Looks just like the picture. Packaged well, but he goes a little heavy on the packaging tape, was a B to open  :twisted:
I'll be doing the timing belt / water pump as soon as myke gets back to me  8)
Reply #6August 07, 2008, 07:27:35 pm
FWD.MOTION
  • 170
Diesel Timing Tool
« Reply #6 on: August 07, 2008, 07:27:35 pm »
im really interested to take the time opening this guys over the top packaging. how long did it take to arrive?
was there the extension that goes onto the ip from the dial gauge in the kit? did it come with a box for storage?
BASELYNE
Reply #7August 08, 2008, 05:02:34 am
Choppercat
  • 42
Diesel Timing Tool
« Reply #7 on: August 08, 2008, 05:02:34 am »
21 days today and still waiting but anything from anywhere takes 3 week to be delivered aroud here it seems  :(
Maybe today...I'll post about the packaging.
'93 AAZ Golf
'99 Jeep TJ
Reply #8August 08, 2008, 05:56:39 pm
Choppercat
  • 42
Diesel Timing Tool
« Reply #8 on: August 08, 2008, 05:56:39 pm »
Quote from: "FWD.MOTION"
Came in today (21 days later) but like I said before I'm in a geographical oddity- three weeks from anywhere! :roll:  Packaging was excelent and a tad heavy with tape.
And yes it has an extention rod for the IP and only a storage box for the gauge. The rest is loose hardware :cry:
'93 AAZ Golf
'99 Jeep TJ
Reply #9August 12, 2008, 04:02:19 pm
FWD.MOTION
  • 170
got mine
« Reply #9 on: August 12, 2008, 04:02:19 pm »
I got mine today. Package was so protected in tape an paper that its nuts. Im glad to announce that the quality of the kit is really high.
Nice time in shipping and very very very well protected!
Plus 1 for a good buy
BASELYNE
Reply #10August 12, 2008, 08:41:26 pm
beowulf
  • 19
Diesel Timing Tool
« Reply #10 on: August 12, 2008, 08:41:26 pm »
I bought the same kit.  This will be first timing belt ever.  Does anyone know of any instructions on how to assemble the three pieces for the dial indicator and adapter?
Diesels do it by squeezing real hard.
Reply #11August 13, 2008, 10:15:28 am
dieselsmoke
Diesel Timing Tool
« Reply #11 on: August 13, 2008, 10:15:28 am »
I got one of these as well. How far on do you push the adapter piece onto the dial gauge?? If you push it on all the way it looks like the extension rod sticks out too far.
Reply #12August 25, 2008, 10:06:46 am
RandoM
  • 7
Diesel Timing Tool
« Reply #12 on: August 25, 2008, 10:06:46 am »
Sorry about the off topic, but I was wondering if this item was absolutely required to swap the IP...
I mean, i have to swap my engine and make everything work by next weekend :S
Isn't there some kind of markings i can use for "TEMPORARY" timing and make it perfect when i receive that kit ?
Reply #13August 25, 2008, 10:56:14 am
Quantum TD
  • 1195
Diesel Timing Tool
« Reply #13 on: August 25, 2008, 10:56:14 am »
If you use the Bentley manual specs, and time it spot-on the mark on top of the injection pump and line it up to the mark on the mounting bracket, you'll end up having the pump out of whack. I usually find that when I use that mark as a reference, and then time with a dial indicator, it's usually retarded by about 30-50mm. So, the car will run, but you won't have much power and you're gonna have a rough idle at startup.
Reply #14August 26, 2008, 05:50:07 am
FWD.MOTION
  • 170
Diesel Timing Tool
« Reply #14 on: August 26, 2008, 05:50:07 am »
I was told that the valve clearance when you set it up without the Ip is sooo close the cars bairly running...
I can report for a fact that you will have less power and a rough idle but It will run! Probubley youd be better off just marking the belt with a perminent marker and then just count teeth on the new one!
If you have never done the timing before or never heard the car running properly then you will probubley not noticed the "sound" of a properly timed engine as appose to the ghetto timing version
good luck, If I was you I wouldnt drive the car for as long as I did without getting it tunned at a performance shop
now my pumps on the right tooth and running at 1.0 and wittout the timing tool you will not know what 1.0 is or where
BASELYNE
