Author Topic: Cheap instrument pod  (Read 5838 times)
July 24, 2008, 08:50:01 pm
witoke
  • 76
« on: July 24, 2008, 08:50:01 pm »
Many thanks to the genius who thought of using PVC elbows for mounting dash instruments. I built a nice (-ish) cluster for my TD vanagon that mounts flush to the dash above the ashtray. Angle was perfect with a 22 degree elbow, swiveled slightly to point at the driver.
Glued the PVC to a piece of aluminum plate and mounted the EGT, Boost and oil temp gauges with space for another pod if I can think of any other info I might need. Sprayed it all flat black and it almost looks good while giving me a much better arrangement than having them wedged on the dash.
Try it, you'll like it...
Reply #1July 24, 2008, 09:03:27 pm
VW_Commuter
  • 355
« Reply #1 on: July 24, 2008, 09:03:27 pm »
Pics?
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #2July 24, 2008, 09:12:29 pm
witoke
  • 76
« Reply #2 on: July 24, 2008, 09:12:29 pm »
I did want to do that but there are no obvious links on the page for that that I can see. Anyone give me a quick tutorial?
Reply #3July 25, 2008, 06:15:50 am
VW_Commuter
  • 355
« Reply #3 on: July 25, 2008, 06:15:50 am »
When making a post there is a button labeled "Img*", and when you place your cursor over it you see "Insert image:  (alt+p)".  Post your pics somewhere that people can reach with a browser, then in your message you would put " and your pic will appear in your post.[/img]
So when you put a valid URL/web address in for a picture on someplace like photobucket or snapfish it will give you .
Greg
Reply #4July 25, 2008, 05:44:45 pm
fdnyguy
  • 499
« Reply #4 on: July 25, 2008, 05:44:45 pm »
I'm adding gauges to my car ($25 sunpro water, oil, volt) and adding it below the ashtray at the shift console.
I do personally think it is a bit too low. Would love to see pics/specs to see it angled towards the driver anywhere in the car. Thanks.
Stay well.
Never forget what a "Religion of Peace" did on 9/11/01.
2015 Passat TDi. 27k
1998 Jetta 1.9TTDi 228k .
2002 F250 7.3 TD   63,000 miles. Sold.
1980 Mack CF Fire Engine. Working on it.
2007 Dodge MegaCab 5.9 Cummins. Nice, but plagued with issues
Reply #5July 25, 2008, 06:55:56 pm
VW_Commuter
  • 355
« Reply #5 on: July 25, 2008, 06:55:56 pm »
Quote from: "fdnyguy"
Stay well.
I'm considering this MK2 Full Pillar Dual Gauge Pod for my boost and EGT gauges.  It looks pretty good and  isn't bad at $55.
Greg
Reply #6July 25, 2008, 08:22:44 pm
Turbinepowered
  • 1206
« Reply #6 on: July 25, 2008, 08:22:44 pm »
Wonder if that pillar pod would work on a Fox.
Reply #7July 25, 2008, 09:08:27 pm
VW_Commuter
  • 355
« Reply #7 on: July 25, 2008, 09:08:27 pm »
I don't know but it looks awfully nice but would it turn me into the German equivalent of a ricer?:D  What is that, spatzl?
Greg
Reply #8July 25, 2008, 09:17:00 pm
« Reply #8 on: July 25, 2008, 09:17:00 pm »
Quote from: "VW_Commuter"
Stay well.
I've been looking at that one also.
I want to run a fuel pressure gauge and a water temp gauge as well as my  current gauges.
Would like to run a oil temp gauge too but I don't have a place to put another gauge even if I by the A pillar mount.
Reply #9July 25, 2008, 09:22:13 pm
VW_Commuter
  • 355
« Reply #9 on: July 25, 2008, 09:22:13 pm »
Quote from: "zukgod1"
Could you use the same gauge for water and oil temp and just run a switch to select between the two?  Or could you get one of those dual guages like this?
Greg
Reply #10July 25, 2008, 09:24:27 pm
VW_Commuter
  • 355
« Reply #10 on: July 25, 2008, 09:24:27 pm »
Or maybe this one, which I really like.
Greg
Reply #11July 25, 2008, 11:01:15 pm
« Reply #11 on: July 25, 2008, 11:01:15 pm »
That's what I do... works a treat. It's actually pretty handy to be able to compare water temp to oil temp with the flick of a switch.
Also do it with my pressure gauge:  fuel pressure / oil pressure.
Four readings and only two gauges... there's only so much room in the cockpit !!
Reply #12July 25, 2008, 11:39:22 pm
« Reply #12 on: July 25, 2008, 11:39:22 pm »
The only problem I can see whit that is I'm kinda anal about all my gauges being the same.
I'm running Auto meter Ultra lite II's now and I don't think it would be cost effective to switch at this time.
I guess I could still just use 2 senders though like you are talking about and still use the same gauges.
And I think Icould just mount the FP gauge under the hood.
Reply #13July 26, 2008, 12:19:13 pm
madmedix
  • 204
« Reply #13 on: July 26, 2008, 12:19:13 pm »
I've got two current setups - the Jetta had them in the centre console at the bottom where the open "glove box" area is...too low...so I cut out the top tray of the console and replaced it with a piece of thick aluminum plate. Used PVC elbow that I cut on two axis to angle them not only up but about 22 degrees towards the driver (I'm over 6'5"). Worked great until some assh*#$ apparently really liked them and took 'em :-(
The second setup is in the golf and I put a trio set where the stereo normally goes and moved the stereo (DIN mount) to the centre console. Best setup for me.
Cheers,
Andy
'90 TD Jetta
Reply #14July 28, 2008, 06:40:37 am
riddleyo
  • 130
« Reply #14 on: July 28, 2008, 06:40:37 am »
Made my own for about $2 in plexi-glass and some time:
Plexi-glass is really brittle so some ABS plastic would be a better choice. But I just cut up some plexi-glass, drilled some holes, painted it black, fit some VDO gauges, and mounted it where the old tape player was. Turned out great and cheap.
1985 VW Golf Diesel 1.6L N/A
My Build Thread: http://www.vwdiesel.net/forum/index.php?topic=14607.0
