Author Topic: 1.9 AEF, Bosch pump?  (Read 8250 times)
July 12, 2008, 01:47:31 am
dridgy
  • 3
« on: July 12, 2008, 01:47:31 am »
Hi i have a t25 van with a 1.9 n/a aef polo engine fitted in it. The engine has a lucas diesel pump. is it possible to fit a Bosch diesel pump instead.
If so what pump will fit? ie AAZ? etc.
Thanks
dridgy
Reply #1July 12, 2008, 03:31:01 pm
Sierra94
  • 123
    Dieselsmoke in every stroke... M-Tdi Mazda!!
    • http://www.garaget.org/sierra94
« Reply #1 on: July 12, 2008, 03:31:01 pm »
Itīll fit. If you use the bracket the Bosch IP was mounted to. The centre hole in the Lucas bracket is bigger than the Bosch one.
<-- My M-tdi Mazda B-1800 and my other cars
Reply #2July 15, 2008, 12:16:01 pm
dridgy
  • 3
pump
« Reply #2 on: July 15, 2008, 12:16:01 pm »
thanks man ill look out for one.
cheers
dridgy
Reply #3January 19, 2009, 06:46:13 am
DA-BRT
  • 140
    • http://Zwalve.eu/
« Reply #3 on: January 19, 2009, 06:46:13 am »
I just converted my Polo 6N with AEF engine to a AFN 1.9TDI with mechanical Bosch pump.
Sorry for the crappy pictures. My digigital camera was broken and I took these with my telephone.
Inlet manifold with airtemp. sensor
You can see the small wheel through the cover. (I have to modify it)
I have to install the FMIC and break in the engine. For now low boost, small turbo.
I encountered some problems, but not for the pumpbracket conversion. The brackets from the 1900D 1X and the 1900TD AAZ/ABL are both ok to use.
You can use one from a TDI but that one has got the additional wheel for  the belt. The metal plate to keep the cover in place and the cover it selve aren't suitable for the wheel. I modified them (make some pictures if you like)
Reply #4January 21, 2009, 02:35:55 am
regcheeseman
  • 714
« Reply #4 on: January 21, 2009, 02:35:55 am »
Would you be willing to share some info on your pump configuration - maybe via PM.
PLEASE!
Reply #5January 21, 2009, 04:35:00 am
DA-BRT
  • 140
    • http://Zwalve.eu/
« Reply #5 on: January 21, 2009, 04:35:00 am »
It's not a secret. I modify and sell the 12mm LT pump for usage on the M-TDI engines.
Changed: Govenor, rear mounting bracket, advanced timing mechanism. You can have a look at the link in my signature.
Reply #6January 23, 2009, 07:59:16 pm
DYNOMAX
  • 28
« Reply #6 on: January 23, 2009, 07:59:16 pm »
What kind of sensor used to measure the airtemperature ?
Is it so simple that you can use a EGT sensor ?
Reply #7January 23, 2009, 11:09:38 pm
DA-BRT
  • 140
    • http://Zwalve.eu/
« Reply #7 on: January 23, 2009, 11:09:38 pm »
I used an aftermarket sensor in Ohm resistance. You can also use a outside air temperature meter for it.
for reading it out I used a Temperature controller. I can sell you a set if you like for about 80 and a little bit for sending it to Sweden.
