Author Topic: Kerosene?  (Read 6878 times)
July 08, 2008, 11:12:48 am
Infinitrium
  • 151
Kerosene?
« on: July 08, 2008, 11:12:48 am »
What would happen if I were to run kerosene in my 92 Golf's engine?
Reply #1July 08, 2008, 12:18:40 pm
blkboostedtruck
  • 1535
Re: Kerosene?
« Reply #1 on: July 08, 2008, 12:18:40 pm »
Quote from: "Infinitrium"
it will run! but add some motor oil too it so your pump gets lubed!
i do it all the time! about 1quart oil per 10gallons
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #2July 08, 2008, 12:27:39 pm
Infinitrium
  • 151
Kerosene?
« Reply #2 on: July 08, 2008, 12:27:39 pm »
Would Powerservice or Redline DFC work too?
Reply #3July 08, 2008, 12:33:27 pm
blkboostedtruck
  • 1535
Kerosene?
« Reply #3 on: July 08, 2008, 12:33:27 pm »
what is that? not sure what those are?
Duane
'66 variant 1500S
Reply #4July 08, 2008, 02:29:35 pm
Choppercat
  • 42
Kerosene?
« Reply #4 on: July 08, 2008, 02:29:35 pm »
Jet Fuel is actually just ''cleaner'' diesel. It will burn better and cleaner in your engine but being somewhat drier, you need to add a little bit of oil in it in order to lubricate your pump and injectors. Generally a 50:1 ratio of jet fuel and engine oil, or better yet mixing oil (2 stroke motor oil) is what people have been running. I'm also considering doing it myself with the price of diesel nowadays and having acces to a certain amount of Jet A-1 from work 8).
DIESEL SMOKE IS ADDICTIVE!!!
'93 AAZ Golf
'99 Jeep TJ
Project: '51 Willy's CJ-3A AAZ
Reply #5July 08, 2008, 03:17:11 pm
blkboostedtruck
  • 1535
Kerosene?
« Reply #5 on: July 08, 2008, 03:17:11 pm »
Quote from: "Choppercat"
what i do know about jet fuel it does have anti bacteria inhibiter's and if you have alge growing in your tank it will kill it witch is a good thing but in the same note it will start clogging up filters and other critical component's! once it becomes floating in your tank! but once your past that and the dead alge has past your good to go! i wish mine would hurry up and pass soon
the jet A is cleaner pretty close to kerosene works great in a torpedo heater but diesel wont!
Duane
'66 variant 1500S
Reply #6July 08, 2008, 03:45:42 pm
Dr. Diesel
  • 1341
Kerosene?
« Reply #6 on: July 08, 2008, 03:45:42 pm »
stanadyne lubricity formula is the way to go. double the dose for jet fuel/kerosene as recommended for diesel.
Reply #7July 08, 2008, 04:26:37 pm
Kerosene?
« Reply #7 on: July 08, 2008, 04:26:37 pm »
Kerosene is severly dry. Make absolute certain that you have enough lubrication, or start saving for a new pump. Pumps that die from lack of lubrication are big money to rebuild because usually all the expensive parts (head/rotor and cam) are junk
Reply #8July 09, 2008, 08:32:23 am
Kerosene?
« Reply #8 on: July 09, 2008, 08:32:23 am »
Quote from: blkboostedtruck
Duane
I burn red diesel in my torpedo heater all the time.
Reply #9July 09, 2008, 08:41:32 am
Kerosene?
« Reply #9 on: July 09, 2008, 08:41:32 am »
Quote from: jimfoo
Quote from: "blkboostedtruck"
Duane
Me too.
I've ran both red fuel and kerosene in my turbo style heater.
Reply #10July 09, 2008, 10:03:54 am
blkboostedtruck
  • 1535
Kerosene?
« Reply #10 on: July 09, 2008, 10:03:54 am »
Quote from: zukgod1
Quote from: "jimfoo"
Duane
Me too.
really thats odd! the last time i tried it my torpedo( prolly 10 years now) would not lite! so i drained
it and put kerosine and used jet fuel ever since never tried the diesel in it again! same spark plug and everything!
Duane
'66 variant 1500S
Reply #11July 09, 2008, 12:58:24 pm
Choppercat
  • 42
Kerosene?
« Reply #11 on: July 09, 2008, 12:58:24 pm »
I never wrote that, blkboostedtruck did! :roll:
But I can't see why it wouldn't work? After all it's just a thirsty furnace.
'93 AAZ Golf
'99 Jeep TJ
