Author Topic: need help with 1.6td pump convo  (Read 2011 times)
July 06, 2008, 11:59:04 am
oldskool rich
  • 446
« on: July 06, 2008, 11:59:04 am »
ive built a few pumps now and im no strager to things going wrong but this is different. the pump started as a 1.6 na pump, changed the pump head, plunger, cam plate and springs off an aaz, then added the 1.6 LDA.
it seemed to be going ok for a bit, but then when reved it hits around 3.5k, then gets stuck and wont cum back to idle. why is this happening?
also it produces lots of black smoke but wont hit high bost even with the waste gate blocked. im guessing the timing is too far advanced.
i realy dont understand whats gone wrong with the revs, if i cud sort that then im sure the rest is just down to the set up and timing. cud it be sumthing to do with the n/a pump?
f6squared I.D.S.T
Reply #1July 06, 2008, 12:03:52 pm
oldskool rich
  • 446
« Reply #1 on: July 06, 2008, 12:03:52 pm »
also, if you jiggle the max fuel screw or even just hit it, it returns to idle
 :cry: help
f6squared I.D.S.T
Reply #2July 06, 2008, 12:51:17 pm
Op-Ivy
  • 513
« Reply #2 on: July 06, 2008, 12:51:17 pm »
Try turning down the full load screw (max fuel). If it is set too high it can cause symptoms just like yours or if even higher, climbing rpms.
The fact that touching the screw fixes it might suggest the same.
Reply #3July 07, 2008, 02:34:22 am
oldskool rich
  • 446
« Reply #3 on: July 07, 2008, 02:34:22 am »
ok will give that a go, also wud aaz injectors improve performance?
surly they carry more fuel than the stock 1.6
f6squared I.D.S.T
Reply #4July 07, 2008, 06:02:00 pm
oldskool rich
  • 446
« Reply #4 on: July 07, 2008, 06:02:00 pm »
i tried everything to get the problem to go away, last thing i tried was changing the plunger springs from aaz ones back to 1.6 again, although at that point it was getting late and left a socket on the bottom pully, ended up snapping the cam shaft into 3 peaces and ripping the pully off, so i wont know if it works till tomoz wen i get that sorted :cry:
any ideas wud be greatly appreciated b4 i kill myself :(
f6squared I.D.S.T
