Author Topic: FS/trade- VNT15 (17?)/manifold from TDI (needs rebuild)  (Read 3815 times)
July 03, 2008, 02:31:17 pm
hamradio
  • 282
« on: July 03, 2008, 02:31:17 pm »
I bought this a while back in unknown condition, stuck it on my car, started it up, and oil was pouring out of the turbine.  I'm done with messing with it.  Comes with a cut apart actuator.  It did, however, spool up nicely.  About 1mm of side to side play, seems like just a tad of end to end play (if I pull on or push the shaft hard).  Also has a 1/4" npt drain fitting I welded up for it, and I might be talked into including a 4an oil feed adapter and some downpipe flanges I cut for it.  The part number on it suggests it *may* be a vnt 17, I dunno.  I could post up the numbers if needed.
Make an offer (I don't expect too much), or would trade/cash plus the vnt for a 1.6 TD manifold or manifold/turbo.  Or a set of good injectors.  Actually, I'd probably trade for a lot of things, I love trading stuff.
A couple pics, does not include that oil drain line, and as mentioned, the actuator can is cut apart.
Thanks,
Devan
Reply #1July 03, 2008, 03:07:35 pm
rallydiesel
  • 1880
« Reply #1 on: July 03, 2008, 03:07:35 pm »
Where are you located and could you post the part number?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2July 03, 2008, 06:10:29 pm
hamradio
  • 282
« Reply #2 on: July 03, 2008, 06:10:29 pm »
I'm in minnesota, and the turbo is a GT1749V.  I heard that's a VNT17, but I'm not totally sure.  I could find the vw PN's on the mani and turbo, if needed.
Reply #3July 04, 2008, 10:47:43 pm
AudiVWguy
« Reply #3 on: July 04, 2008, 10:47:43 pm »
I need to buy a VNT manifold, but does anyone know if a VNT 20 will bolt right up to this manifold?
Thanks,
Jeff B.
Reply #4July 05, 2008, 04:29:19 pm
hamradio
  • 282
« Reply #4 on: July 05, 2008, 04:29:19 pm »
I don't know...I'd almost guess not, as the turbine is probably bigger on a vnt20...best bet is to ask around tdiclub.
