Author Topic: two stroke, spark ignition diesel?  (Read 7514 times)
July 01, 2008, 01:01:32 pm
Dr. Diesel
  • 1341
« on: July 01, 2008, 01:01:32 pm »
I went to cut the lawn the other day, and much to my chagrin there was only about 1/5th of a tank of gas remaining in my early '80's lawnboy two stroke mower. Further irritating, was the fact that the jerry can was empty too. I didn't feel like going to get gas, and it was my last opportunity to cut the lawn for another 5 days. Laziness set in, and I mixed 32:1 two stoke oil to Jet A1. (kerosene, mostly!) This went in with the 1/5th tank of gas and it fired right up. With half a turn on the mixture screw, it settled into a nice, lightly smoking two stroke buzz. I did both the front and rear yards and was pleased to note that it actually seemed to use less fuel on this mix than straight gas/oil!
I wonder if the same thing could be done with biodiesel in other gas engine equipment, and to what ratio?
I suppose  that there's just enough gas in the mix to light it all off. I'll try straight kerosene/oil mix when this tank runs out to verify that idea.
I picked this lawnmower up at a junkyard for $20 and it's run flawlessly for two years. Beautiful. :D
Reply #1July 01, 2008, 02:13:14 pm
« Reply #1 on: July 01, 2008, 02:13:14 pm »
This sounds cool..
I have an 18hp rider, I would love to play as well.
Let us know what you come up with and I'll give it a try also.
Reply #2July 01, 2008, 03:15:01 pm
« Reply #2 on: July 01, 2008, 03:15:01 pm »
Once when almost out of gas at home, maybe 1 gal gas in the tank at most, I put about a gallon of diesel in my car and it drove just fine to the gas station. I tried this another time, but with a much higher ratio, and it died about halfway there amid huge clouds of smoke. Kerosene is probably better, but there is a limit. Gas is cheaper anyway.
Reply #3July 01, 2008, 04:44:18 pm
« Reply #3 on: July 01, 2008, 04:44:18 pm »
My brother mixed some biodiesel 40:1 (1 part bio) and ran it in his chevette. He said the car seemed to run smoother.
Reply #4July 01, 2008, 06:58:51 pm
burnt_servo
  • 278
« Reply #4 on: July 01, 2008, 06:58:51 pm »
over the last 15 years since i bought my gas powered air compressor , i've run alot of diesel through it , mainly since if was free  or really cheap ....
it's just a 5 hp briggs ,
what i would do is start it on gas till it got to working temp , then while it was running , fill it up with diesel , then every hour or so , refill it with diesel . ( it would be running all day non stop ) , then run it almost out of diesel  and add a bit of gas , the run it out of fuel .
if i didn't run gas through it and run it for 1/2 an hour or so , deposites from the diesel would build up on the intake valve stem causing it to stick open .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #5July 01, 2008, 08:25:21 pm
Dr. Diesel
  • 1341
« Reply #5 on: July 01, 2008, 08:25:21 pm »
Interesting! This being jet fuel, is quite a bit more refined than diesel. I wonder if a 4 stroke would have similar intake valve buildups on kerosene? I thought maybe one could preheat the inlet air with muffler heat (on a 4 stroke... not so easy on the lawnboy) to help vaporize the kerosene.
Andrew, forums are fueled by people irrisistably adding their grandiloquent 2¢ worth. Nitpicking is part of my job, I'm used to it.  :)
I guess this is why people call it 'dieseling' when a spark ignited engine runs on after the key's shut off!
Come to think of it, my lawnboy did continue to run roughly after i'd switched it's ignition off, until the emergency brake killed it. Hey! It IS a diesel!
Maybe I should up the compression and toss the spark plug in favor of a compression counter piston like diesel model airplanes have. Make her a true diesel. Would probably need a heat gun or ether to get it up to self-sustainable running temps though.
Reply #6July 02, 2008, 12:10:46 pm
« Reply #6 on: July 02, 2008, 12:10:46 pm »
What is a compression counter piston?
Reply #7July 02, 2008, 12:54:14 pm
DonGTI
  • 172
« Reply #7 on: July 02, 2008, 12:54:14 pm »
in model engines instead of a sparkplug you get a metal slug that can be screwed in to increase compression and out to lessen it...
Fast and Cheap is not Reliable
Reliable and Cheap is not Fast
BUT
Reliable and Fast is NEVER Cheap...
                              - someone's wise words after my GTI engine died -
Reply #8July 02, 2008, 06:46:49 pm
« Reply #8 on: July 02, 2008, 06:46:49 pm »
Weird, on both of my RC plane engines there's a glowplug that you put 1.5volts to, start it and then take the power off the GP and your good to go. Ones a 4-stroke and ones a 2-stroke.
Reply #9July 03, 2008, 04:05:29 am
Dr. Diesel
  • 1341
« Reply #9 on: July 03, 2008, 04:05:29 am »
yeah, and they run on glow fuel. but if you had a diesel engine, you'd have a little (usually) allen key on the top where the glowplug sits on a glow engine. Screw it in to increase compression, out to lessen. You can actually convert some sizes of O.S.  (and clones) engines to run on diesel. I picked up the kit, but couldn't find a good source of liquid ether. the kit manufacturer suggested freezing then puncturing a can of quickstart with a brass nail to acquire ether. Scary...
Reply #10July 03, 2008, 02:37:42 pm
Slave2School
  • 531
« Reply #10 on: July 03, 2008, 02:37:42 pm »
During the last great depression people ran much equipment on kero because at that time it was more available and cheaper.  Usually a bit of modding required and you could only do it after teh vehicle was warmed up.  Read the grapes of Wrath, I think it is mentioned in there :D
2002 ford focme wagon
Reply #11July 03, 2008, 04:39:12 pm
Quantum TD
  • 1195
« Reply #11 on: July 03, 2008, 04:39:12 pm »
Quote from: "Slave2School"
See, us dieselknerds are worldly and edgymacated and such.
Reply #12July 09, 2008, 10:09:14 am
smoken u
  • 231
« Reply #12 on: July 09, 2008, 10:09:14 am »
briggs and stratton made a semi-diesel engine, it ran on gasoline until it warmed up then you switched it to diesel.
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
Reply #13September 02, 2008, 05:45:42 am
Dr. Diesel
  • 1341
« Reply #13 on: September 02, 2008, 05:45:42 am »
Well after finally using up my 50/50 kerosene gasoline mix, I switched to straight kerosene (with 32:1 oil mix) It was just as hard to start as normal, (tuning problem I think, because it was the same on gasoline) and took a little longer to run steadily (she's on old girl, bought for $20 from the junkyard) but ran perfectly happily once all settled down.
I wonder if i'd have similar results on veggie oil? For that matter, would the oil mix be neccessary on veggie?  :D
One note, after shutting off the ignition, continued to run in a lopey sort of way. I'd already shut the fuel off a minute earlier to clear the lines. So next time, i'll leave the fuel on and shut the ignition off only to see if it'll run on compression ignition alone!
Cool stuff!
Reply #14September 02, 2008, 07:36:50 pm
« Reply #14 on: September 02, 2008, 07:36:50 pm »
theres some old russian trucks that could be started on gas, and then switched over to diesel.  pretty cool!
its a testament to the fact that diesels dont really need high compression.. just for cold starting  :wink:
