Author Topic: Passat diesel studdering  (Read 3178 times)
June 28, 2008, 08:30:51 pm
rowbus
  • 1
« on: June 28, 2008, 08:30:51 pm »
I have a 2004 Passat which has had a slight studder on the hwy around
60mph.  Dealer has no answer.  Does anyone have a suggestion
Reply #1June 29, 2008, 04:53:14 am
bluemotion
  • 22
« Reply #1 on: June 29, 2008, 04:53:14 am »
Change the timing, fuel quantity and EGR settings in the ECU, and see if that changes anything.  If that doesn't work, then change the overpriced injectors.
Reply #2June 29, 2008, 08:51:59 am
  • 1739
« Reply #2 on: June 29, 2008, 08:51:59 am »
There is an unknown tech bulletin on those . I think it's because the ECU is allowing too much EGR at certain rpms . The quick easy fix is to replace the gasket at the output of the EGR valve with one with a very small hole. Find a metal gasket with a hole about 1 cm instead of 1 inch.
Reply #3July 01, 2008, 10:08:03 am
« Reply #3 on: July 01, 2008, 10:08:03 am »
or just completely eliminate the egr... it will only lead to an early death for your car.  the nice carbon bits will wreck smooth bearing surfaces.
Reply #4July 02, 2008, 12:32:04 pm
  • 1739
« Reply #4 on: July 02, 2008, 12:32:04 pm »
You could eleminate but it'll set of the MIL. Restricing it will cause enough for the MAF to sense the change and think everything's okay. You won't stop all the coking but most.
