mTDI Mechanical TDI Conversions
Bolt on mTDI pump?
Topic: Bolt on mTDI pump? (Read 6509 times)
June 25, 2008, 02:43:03 pm
ThomZe
Bolt on mTDI pump?
June 25, 2008, 02:43:03 pm »
Is a 0460494277 VW
Bosch VE pump from a 1999 T4 bolt on? It's cable throttle steared and have no electronics however..
Would that make a direct fit on my tdi engine? 1z\ahu
BMW E36 320i Automatic
June 25, 2008, 02:44:12 pm
ThomZe
hm
June 25, 2008, 02:44:12 pm »
It's from a 1.9L btw.
June 25, 2008, 03:08:14 pm
snakemaster
Bolt on mTDI pump?
June 25, 2008, 03:08:14 pm »
that is a 1.9 td pump by the look of it(i could be wrong) , that would be crap on a tdi
Glenmorangie single highland malt
June 25, 2008, 03:14:18 pm
ThomZe
hm
June 25, 2008, 03:14:18 pm »
Okay, I don't have a "program" or anything to check the number in so I don't know
if it's just a ordinary 1.9td\aaz pump then it's of no use
June 26, 2008, 09:33:52 am
Bolt on mTDI pump?
June 26, 2008, 09:33:52 am »
This pump is on AAZ from Passat 1.9TD
June 26, 2008, 05:26:16 pm
Tintin
Bolt on mTDI pump?
June 26, 2008, 05:26:16 pm »
Have you looked at this post:
http://vwdiesel.net/phpBB/viewtopic.php?t=14717
I can give you minimal info on + or - bolt on M-pump, if you see one for sale, ask the vendor for the P/N and tell me the number, It's the best and easy way to go to M-TDI.
July 01, 2008, 08:24:12 pm
bluemotion
User+
Bolt on mTDI pump?
July 01, 2008, 08:24:12 pm »
Can you change the timing spring to get a more desirable timing curve for the M-TDI pump?
Bolt on mTDI pump?
