Author Topic: Which pump will fit my AAZ?  (Read 4563 times)
June 23, 2008, 12:27:46 pm
AadmanZ
« on: June 23, 2008, 12:27:46 pm »
Hallo Gents,
I was here a year ago with some questions on the infamous pulley problem. Well, that has been fixed. Head was rebuilt, newer model pulley etc.. A lot of Euros, but at least that part of the engine is as good as new. :wink:
A new problem has arisen however: the diesel pump has died. The axle of the pump has too much free play. It's at my garage and I have not seen it yet, but I take his word for it.
The question now is, which pumps will fit (as in: bolt more or less straight on, I am not looking at building a diesel dragracer) as there seem to be an awful lot of pumps on ebay, (1.6, T3 etc) but I am not sure which ones I can safely go for..
This guys says this one will fit, but who is he? He's only selling it :)
http://cgi.benl.ebay.be/T3-Einspritzpumpe-ESP-1-6-1-7-1-9-TD-JX-KY-AAZ-LLE-Doka_W0QQitemZ380039023126QQihZ025QQcategoryZ61258QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting
Reply #1June 23, 2008, 06:56:46 pm
« Reply #1 on: June 23, 2008, 06:56:46 pm »
For best results get one off of an AAZ motor.
Also, bear in mind that there are 2 different mounting diameters, 50mm and 68mm (I think). You'll have to change the bracket if you don't get one that matches yours. If you have a split pulley it's the larger size (typically)
Reply #2June 24, 2008, 12:06:52 am
AadmanZ
« Reply #2 on: June 24, 2008, 12:06:52 am »
ok, good to know, thanks..
Reply #3June 24, 2008, 01:55:17 am
AadmanZ
« Reply #3 on: June 24, 2008, 01:55:17 am »
By the way, is the difference on the engine side or the pump side?
i.e. do I need to get a bracket that matches the pump or one that matches the engine?
Reply #4June 24, 2008, 06:28:22 pm
« Reply #4 on: June 24, 2008, 06:28:22 pm »
matches the pump
