Author Topic: VW LT pump 0 460 424 138 for mTDI?  (Read 8715 times)
June 11, 2008, 02:36:28 pm
BGA
  • 48
« on: June 11, 2008, 02:36:28 pm »
I have found this pump at a scrapyard
http://picasaweb.google.se/bogunnar.andersson/MyPictures
It is a Brazil built 0 460 424 138.
Will the TDI 1.9 belt drive fit?
4 cyl LT pumps from around 97, 98 has been mentioned in this forum as suitable for mTDIs. Is this the PUMP?
If yes, what else changes has to be done to get a good mTDI pump?
Bo Gunnar
Reply #1June 11, 2008, 02:59:27 pm
BGA
  • 48
Further info on above subject
« Reply #1 on: June 11, 2008, 02:59:27 pm »
Its a LT 46 -99
engine code AGK
92 kW
Bo Gunnar
Reply #2June 13, 2008, 10:54:12 am
snakemaster
  • 405
« Reply #2 on: June 13, 2008, 10:54:12 am »
to me that looks like a good pump to put on a mtdi but  the ofset of the pump pully could be out  due to that adapter plate
Reply #3June 19, 2008, 08:17:54 pm
westyman
Re: VW LT pump 0 460 424 138 for mTDI?
« Reply #3 on: June 19, 2008, 08:17:54 pm »
Yes, it is one of the best options. If you have a 1Z/AHU/AFN, the stock TDI pump pulley fits directly. If you have a later engine you'll need to swap over the hub and pulley both from the original electronic pump. This pump is as close to bolt-on-and-run as you can get. You''l want to run some bigger nozzles though.
Karl
Quote from: "BGA"
