Author Topic: 1.9/1.6 hybrid engine  (Read 7032 times)
June 02, 2004, 09:06:04 pm
dieselpower
  • 177
« on: June 02, 2004, 09:06:04 pm »
hey,
I have a 1.6ltd in my car right now.  I have the chance to pick up a 1.9ltd for really cheap except the head is toast :( anyway i have a 1.6td hydrolic lifter head in my garage collecting dust and was wondering if the 1.6l head will fit on a 1.9l block, and if i did this would i find any increase in power of the complete 1.6l?
thanks for the help
84 rabbit 1.6TD
because real cars don't have sparkplugs
Reply #1June 03, 2004, 04:54:11 am
Dr. Diesel
  • 1341
« Reply #1 on: June 03, 2004, 04:54:11 am »
I think it'd work. BUT... The 1.6L has smaller intake valves. I bet the effect would be a stronger bottom end torque, say til 3000, and a very choked off higher end. Would be better to have the head repaired if possible and jam it on a 1.6L
Reply #2June 03, 2004, 06:36:53 am
VWRacer
  • 649
« Reply #2 on: June 03, 2004, 06:36:53 am »
Hey, don't throw away that knackered head! :D
(Folks here may need parts off it... ;))
Stan
C-Sports Racer
Reply #3June 03, 2004, 03:03:40 pm
dieselpower
  • 177
« Reply #3 on: June 03, 2004, 03:03:40 pm »
i wasnt planning on throwing anything away if i get the car.  i dont want to spend too much money on it because i have a scirocco out back and theres a written off 03 jetta TDI localy that I want to get to put into the scirocco.  Its a lot of work but it would be a fun car once its done :D
84 rabbit 1.6TD
Reply #4November 13, 2004, 02:52:07 pm
srivett
  • 318
« Reply #4 on: November 13, 2004, 02:52:07 pm »
Here's one that'll make you guys sick.   :twisted:
I am able to get a Jetta 1995 1.9TD with 180,000km on it for 250 bucks but it's more or less a long block.  Would I be able to dress it in 1.6NA parts?  I think I'll have to toss the turbo and injector pump that's on the engine due to a mishap involving a fire and an aftermarket stereo.  :lol:   Basically, picture this thing with only the vacuum pump left as origional.  Will everything line up on the cam belt?  The reason I'd do this is that my 1.6 is down to 340/360 PSI so it's dying.
Thanks, Steve
ps.  I could look into buying the engine/tranny and subframe with steering rack to part out if there is interest.  I would prefer to have people come pick the parts up in Sudbury if they are big.  The head on this engine is supposed to be new but it's hard to tell due to the fire...
1992 1.6D Golf - 412K km
Reply #5November 14, 2004, 02:18:44 pm
janb
  • 167
« Reply #5 on: November 14, 2004, 02:18:44 pm »
I have a couple 1.9's w/ 1.6 hyd heads / intakes.
all fits x-cept timing cover, I use steel ones from A1's (need to fab 16mm offset bracket), and exhaust is 16mm taller in 1.9 (need to tweak your header pipe)
run fine, significant improvement in torque, probably would be better performance with 1.9 'D' intake and head, but I don't notice a difference when comparing with stock 1.9's (IDI's)
The Stealth Rabbit
VW-d's are forever
Reply #6November 14, 2004, 07:12:38 pm
srivett
  • 318
« Reply #6 on: November 14, 2004, 07:12:38 pm »
It's good to hear somebody has done this.  The head should be fine so I'll try to get it going without removing it.  Which timing belt did you use when you put the 1.6 head on?
Have you tried to put in the older 1.6 oil pump and vacuum pump?  They are a bit of an item due to the change in drive engagements.
The oil pan gasket is really expensive on the AAZs too...I'll have to see if I can use my old 1.6 pan and get a new gasket for that instead.
Thanks, Steve
Reply #7November 14, 2004, 08:09:59 pm
ricosuave
  • 244
« Reply #7 on: November 14, 2004, 08:09:59 pm »
that sounds kinda cool - try it and lets see what happens!
Reply #8November 15, 2004, 07:48:39 am
2mn2
« Reply #8 on: November 15, 2004, 07:48:39 am »
Parts Place has a 1.9 liter pamphlet that covers putting a 1.6 head on a 1.9 block among other things. It runs about $6.00. It is worth the money.
They also have a selection of 1.9 blocks and engine parts. Be very sure of what you want before ordering anything from them.
m alexander
Reply #9November 16, 2004, 06:50:44 pm
janb
  • 167
« Reply #9 on: November 16, 2004, 06:50:44 pm »
Quote from: "srivett"
...Which timing belt did you use when you put the 1.6 head on?
Thanks, Steve
you use a specific belt for 1.9, more teeth/longer (-P instead of -F, I think) (BTW intermediate shaft pulley is smaller too)
The hole in block for vac pump is different dia on 1.9 (bigger)
Oil Pan gasket for 1.9 is likely "windage tray" (rubber + metal splash shield) ~$25.  you can use a molded gasket ~$10 or the generic gasket ~$2.  pans should be same
jb
The Stealth Rabbit
VW-d's are forever
Reply #10November 18, 2004, 03:58:22 pm
dieselpower
  • 177
« Reply #10 on: November 18, 2004, 03:58:22 pm »
Janb,
where do you get your gaskets. i'm looking to replace mine and went to the dealership and it was something like 30 bucks for my 84 1.6, and i get parts for cost.
thanks
Mark
84 rabbit 1.6TD
Reply #11November 19, 2004, 12:05:38 pm
janb
  • 167
« Reply #11 on: November 19, 2004, 12:05:38 pm »
Janb,
Halsey Import (portland, OR) 1-800-792-0081  or 1-503-256-3155
I hear there are some good sources in BC, (BowWow?) but there are plenty of northerners on this site that can lead you to a econo solution, if not, give me a message, and I will contact a BC guy to get his rec's.  I also have a contact in Sk, that might have a source.
janb
The Stealth Rabbit
VW-d's are forever
Reply #12November 22, 2004, 01:56:18 pm
type53b_gtd
  • 118
    • http://scirocco.cs.uoguelph.ca/gtd/
« Reply #12 on: November 22, 2004, 01:56:18 pm »
Quote from: "Dr. Diesel"
The 1.6 has the same sized valves, but the ports are smaller.  The 1.9 has the "D" ports.
I just finished rebuilding a 1.9 head (keyway disaster) and I used the same parts as I used on the last 1.6 head I rebuilt.  The later 1.9's have 7mm valves and guides, but the earlier ones use the same valvetrain as the hydro 1.6 TDs.
My plan is to put a 1.9 head on a 1.6 block to improve airflow.
Drew
