Author Topic: Losing MAJOR amounts of oil  (Read 6788 times)
June 08, 2008, 07:05:55 am
The Mad Hatter
  • 85
« on: June 08, 2008, 07:05:55 am »
Hello all.  I've got an 85 1.6L Golf.  She's losing oil at an alarming rate.  I drive 120 miles a day at 65 mph.  The back of the car is covered with a black oily substance, which i'm assuming is oil, since my dad's diesel golf (identical to mine) doens't do that, so i know its not diesel fuel.  I'm going thru at least a quart a day.  Any idea what i need to fix.  Valve seals maybe?  Or is my motor gone?  Thanks for any help!
Reply #1June 08, 2008, 07:38:57 am
« Reply #1 on: June 08, 2008, 07:38:57 am »
could be a number of things.  clogged breather, worn rings, worn valve seals...
Reply #2June 08, 2008, 07:39:56 am
The Mad Hatter
  • 85
« Reply #2 on: June 08, 2008, 07:39:56 am »
What things should i check to see what it could be?
Reply #3June 08, 2008, 08:06:03 am
« Reply #3 on: June 08, 2008, 08:06:03 am »
compression check, and then leak down test.
You are refering to the very back of your car being covered in oil, not the firewall correct?
Reply #4June 08, 2008, 08:17:24 am
The Mad Hatter
  • 85
« Reply #4 on: June 08, 2008, 08:17:24 am »
Yes, the back of the car is oily.  I'm not familiar with a leak down test.
Reply #5June 08, 2008, 08:29:13 am
« Reply #5 on: June 08, 2008, 08:29:13 am »
Does it appear to be coming out the tail pipe or from under the car?
You can have a leak from the engine and still get oil all over the rear of the car.
Does it leave a puddle when you park?
Reply #6June 08, 2008, 08:44:58 am
Quantum TD
  • 1195
« Reply #6 on: June 08, 2008, 08:44:58 am »
Consumption that high usually means worn rings/cylinders. My pickup used about 2-3 qts every 400-500 miles and the rings were roasted. I suspect you're in the same boat.
I'd pull the crankcase breather tube, and check for heavy blowby and/or white smoke puffing out of the tube. If you have one, the other, or both, then you're probably looking at a rebuild.
Reply #7June 08, 2008, 09:05:23 am
The Mad Hatter
  • 85
« Reply #7 on: June 08, 2008, 09:05:23 am »
Yes.  I hadn't checked before, but the whole underside of the car is coated in oil.
Reply #8June 08, 2008, 09:19:21 am
The Mad Hatter
  • 85
« Reply #8 on: June 08, 2008, 09:19:21 am »
Ok, i spoke with my dad, i was at his house yesterday, and i left a huge puddle of oil at his place.  So, i've got a leak somewhere.  Any common places?
Reply #9June 08, 2008, 09:56:29 am
gigaz2
  • 626
« Reply #9 on: June 08, 2008, 09:56:29 am »
there are a lot of gaskets that can leak, I wash my engine to locate them more easily.
Reply #10June 08, 2008, 10:14:00 am
« Reply #10 on: June 08, 2008, 10:14:00 am »
oil dipstick usually leaks a lot when it goes, other then that there is all the crank/cam seals and the VC gasket. Upgrade to a rubber one if it is leaking
Reply #11June 08, 2008, 10:41:29 am
shegel
  • 312
« Reply #11 on: June 08, 2008, 10:41:29 am »
when my valve cover gasket went. i was losing about 3 quarts every 50 miles.d
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #12June 08, 2008, 10:48:07 am
The Mad Hatter
  • 85
« Reply #12 on: June 08, 2008, 10:48:07 am »
b_y_$, when you say dipstick, do you mean at the top where you pull it out, or down in the pan?
Supposedely, when i had the IP pump done, the valve cover gasket was replaced as well.
Reply #13June 08, 2008, 10:50:30 am
gigaz2
  • 626
« Reply #13 on: June 08, 2008, 10:50:30 am »
down where it meets the block, it should have a oring. when that fails ( common) lots of oil is lost.
Reply #14June 08, 2008, 04:41:58 pm
« Reply #14 on: June 08, 2008, 04:41:58 pm »
Quote from: "gigaz2"
that's the one I meant.
Losing that much oil it should be easy to find. Pressure wash the engine and top up the oil and just sit there reving it from the engine bay.
