The Famous 1.6TD Boost pin
Topic: The Famous 1.6TD Boost pin (Read 9449 times)
June 06, 2008, 11:17:28 am
ThomZe
June 06, 2008, 11:17:28 am »
Hi, Now I read alot about the boost pin all over this forum, and alot of other diesel forums.
Some people reccomend it, like it's a must have, others disagree, alot of different opinions.
But does anyone really have a proof that it works? I won't take out and hunt one down unless It's really worth it.
Sorry if it's been up before, but I need some clarification
BMW E36 320i Automatic
June 06, 2008, 11:32:56 am
saurkraut
June 06, 2008, 11:32:56 am »
Its everything you've heard about, and more:
Read:
http://www.vwdiesel.net/phpBB/viewtopic.php?t=579
Its the most "aggressive" pin in the vw line up.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
June 06, 2008, 11:47:42 am
ThomZe
great
June 06, 2008, 11:47:42 am »
Hehe cool then I'll trust that. But is it a standard part on 1.6td's or is it a rare part to find
June 06, 2008, 11:59:41 am
saurkraut
June 06, 2008, 11:59:41 am »
Its standard on every 1.6TD with an LDA.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
June 06, 2008, 12:06:43 pm
June 06, 2008, 12:06:43 pm »
Also standard in any Cummins VE pump.
June 06, 2008, 01:26:43 pm
ThomZe
ow
June 06, 2008, 01:26:43 pm »
Thank's guys, I'm appreciating it
June 06, 2008, 02:05:04 pm
gigaz2
June 06, 2008, 02:05:04 pm »
you can also grind the 1.9 one, or buy the part from a bosch supplier.
(don't know the reference)
June 06, 2008, 02:29:50 pm
ThomZe
hmm
June 06, 2008, 02:29:50 pm »
I can grind my own one down? But is that possible to do "right" and if so, Has anyone done it? I'll like to see a pic of that
To know EXACTLY where to grind and so..
June 06, 2008, 02:42:31 pm
June 06, 2008, 02:42:31 pm »
who disagrees? they need to ride in a car with one and one with out one, big difference
June 06, 2008, 02:47:19 pm
ThomZe
hmm
June 06, 2008, 02:47:19 pm »
Im just interested to see one, homegrinded
Don't wanna mess thing up you know.. Only for my own sorry sake, I'm in a "learning about diesel" phase
June 06, 2008, 03:00:35 pm
June 06, 2008, 03:00:35 pm »
I have 2 custom ground pins, running one of them now.
1st one is ground for a very aggressive fuel delivery and the 2nd is ground for low fuel delivery for the first 3/4 of the ramp then a bit more aggressive than the 1st pin so while putting around I an drive with less smoke but at higher RPM's I can get more fuel if I want.
Currently running the 2nd pin and I still have to much smoke putting around, my k24 doesn't build boost till 3000 rpm at this elevation.
I need a tiny turbo for around town and the k24 for high rpms, a VNT25 would be SAWEEEETTTTTTTTT!!!!!!!!!!!!
Reply #11
June 06, 2008, 05:15:13 pm
burnt_servo
Reply #11 on:
June 06, 2008, 05:15:13 pm »
http://vwdiesel.net/phpBB/viewtopic.php?t=13182&highlight=
i have pics of my ground pin there ....
make sure you polish the pin after grinding .....
do a google search on "old smokey fuel pin " there should be some hits on that aftermarket cummins ve fuel pin .
1990 jetta , tweaked pump , tweaked turbo , ported head 2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #12
June 07, 2008, 04:25:05 am
ThomZe
woho
Reply #12 on:
June 07, 2008, 04:25:05 am »
danm, I just grinded my stock pin down a bit, not that much but a little so it got some more aggressive looks.. WOOOHAA suddenly there was no more car, but a beast.. Smokes now, didnt before, and it actualy moves.. It can move!?!?!
Danm, I want a 1.6td pin now, it's sure to be better than the little grind I did myself, my concerns now concentrates around the engine itself.. Can it take it? I'm driving 0.9 bar tops now.. 0.7 before
Reply #13
June 07, 2008, 06:35:26 am
Reply #13 on:
June 07, 2008, 06:35:26 am »
Just make sure you get an EGT gauge before you go to far. You can actually grind 4 different flat profiles in a 1.9 pin, and just turn it to the one you want.
Reply #14
June 07, 2008, 03:19:39 pm
Choppercat
User+
Reply #14 on:
June 07, 2008, 03:19:39 pm »
The OEM boost pin for a 1.9 TD has about 1 mm of recess ground into it. I ground mine at 2 mm and made a noticable increase in power without too much smoke. Than I ground an extra mm (3mm total) and the cars behind me tended to ''dissapear''
. I'll go back to 3 mm when I get my intercooler installed but for now, not having an pyrometer and not willing to melt anything, I'll stick to 2mm :oops: . For the record, my max fuel screw is at +1 turn and everything else accordingly, K14 turbo and 2.5'' straight exhaust
DIESEL SMOKE IS ADDICTIVE!!!
'93 AAZ Golf
'99 Jeep TJ
Project: '51 Willy's CJ-3A AAZ
