Author Topic: dynamic timing ..??  (Read 3808 times)
June 04, 2008, 10:16:25 am
burnt_servo
  • 278
dynamic timing ..??
« on: June 04, 2008, 10:16:25 am »
anyone know the dymanic timing , assuming a static timing of 1mm ( 1.6 turbo ) .
vince walden's how to page mentions 12 degree's before top dead center ... off the top of my head , that seems a bit to advanced to me  .
thanks guys :)
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #1June 04, 2008, 10:26:17 am
dynamic timing ..??
« Reply #1 on: June 04, 2008, 10:26:17 am »
My not working well timing light hooked straight to my tiny tach transducer was seeming to show 11 degrees. You have to think, why should it be much different from a gas engine, especially with Diesel's slower flame front?
I'll have a better idea when I get my real timing light adapter.
Reply #2June 04, 2008, 10:35:38 am
burnt_servo
  • 278
dynamic timing ..??
« Reply #2 on: June 04, 2008, 10:35:38 am »
seems like the last few engines i've worked on  , the spec was several degree's after tdc ....
the one that easily comes to mind is the mitsubishi diesel in the d50 and ford ranger , it's spec'd at 5 degree's after tdc .
i'm just about to order some new nozel's and maybe up my pop presure a bit on the injectors , then thought i should find out what the dymanic timing should be ,  then measuing what mine actually is before taking anything  apart .
thanks man :)
Reply #3June 04, 2008, 07:24:43 pm
dynamic timing ..??
« Reply #3 on: June 04, 2008, 07:24:43 pm »
Yeah, dynamic timing info is a bit of a Holy Grail, but every once in a while I find a clue.
Brickyard's site in the UK has some spec sheets that include dynamic timing info.... for example:
http://www.brick-yard.co.uk/VehicleSpecific/T3/info/enginedata/dsl/KYdata.htm
The engines he lists are European models so not quite a 1:1 spec comparison, but the typical values are 12-16 degrees BTDC.
Sadly the AAZ page is broken   :cry:
Reply #4June 04, 2008, 07:47:40 pm
clbanman
  • 705
    Cambridge, Ontario
dynamic timing ..??
« Reply #4 on: June 04, 2008, 07:47:40 pm »
If you think about the combustion process in combination with the internal dynamics of the engine, you would never want the process to start after TDC.  If you wait until the piston has already passed TDC to fire your fuel mixture, the compressed mixture is already expanding, and your flame front is not instantaneous.  Ideally you want to initiate ignition at a point that creates maximum combustion pressure on the piston for as long as possible on the down stroke, and you can only do that by firing at some point prior to TDC.
Calvin
91 VW Golf 1.6NA 5spd
Reply #5June 04, 2008, 08:10:33 pm
dynamic timing ..??
« Reply #5 on: June 04, 2008, 08:10:33 pm »
since i have my flywheel off the motor, i was wondering if i could 'mark' the degree's on it for when using the timing light?  would be pretty awesome to get a 'real' reading on the actual injection time.  (not that it would be THAT off, but still)
i also want to mark the opposite end of the flywheel for measuring the other two injectors opening sequence.  getting a bit anal here, but opening pressures can be crucial  :wink:
Reply #6June 04, 2008, 08:16:21 pm
dynamic timing ..??
« Reply #6 on: June 04, 2008, 08:16:21 pm »
Quote from: "jtanguay"
Great minds think alike... when I had my AAZ apart I punched a mark at 12 BTDC just in case.
My gasser timing light is not fancy enough to be adjustable, but that's the other option... use the TDC mark and dial the reading on the timing light.
Reply #7June 05, 2008, 05:43:28 am
saurkraut
  • 904
dynamic timing ..??
« Reply #7 on: June 05, 2008, 05:43:28 am »
How many teeth are on the flywheel?
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #8June 05, 2008, 08:23:10 am
dynamic timing ..??
« Reply #8 on: June 05, 2008, 08:23:10 am »
Easier to get a timing light that's adjustable I would think.
At least if you don't have your trans off already anyway.
Reply #9June 05, 2008, 08:55:36 pm
Tintin
  • 1279
dynamic timing ..??
« Reply #9 on: June 05, 2008, 08:55:36 pm »
With my timing light and piezo sensor I can only read the timing at idle and very low RPM, past 1800-2000rpm the piezo seems to be too sensitive to give the correct signal, much vibration interference and the timing light start to flash out of control.
On-boost at full throttle is another story than only 10BTDC, but hard to monitor.
Reply #10June 06, 2008, 12:08:45 pm
dynamic timing ..??
« Reply #10 on: June 06, 2008, 12:08:45 pm »
WOHOO!!! 1 working timing light adapter arrived today. I know my timing was retarded more than it should be. Checked it, and it's right at TDC, so now I can play and find what works best, then post up the results.
Reply #11June 06, 2008, 03:11:27 pm
dynamic timing ..??
« Reply #11 on: June 06, 2008, 03:11:27 pm »
Quote from: "jimfoo"
So where did you get it jimfoo?
Reply #12June 06, 2008, 06:11:19 pm
dynamic timing ..??
« Reply #12 on: June 06, 2008, 06:11:19 pm »
Ebay, of course.
