Author Topic: Best IP for an N/A  (Read 1569 times)
May 26, 2008, 07:49:57 pm
silvertdi
  • 125
Best IP for an N/A
« on: May 26, 2008, 07:49:57 pm »
I've got an 81 N/A.  I've been bouncing back and forth between building a TD or just sending my IP to Giles.  Before I send it off to Giles I thought I'd ask if there is a better pump that I should get and send that off to Giles instead, ie better piston, more features, etc? Thanks.
Reply #1May 27, 2008, 11:58:30 am
Best IP for an N/A
« Reply #1 on: May 27, 2008, 11:58:30 am »
Well if you are even considering converting to TD I would have Giles add the LDA. You can still run it without the turbo but when you add the turbo your already set..
As far as a better pump is concerned probably better off to just call Giles.
If he is building it he can tell you better than anyone.
