Author Topic: Bigger Brakes  (Read 27800 times)
Reply #30July 28, 2005, 11:13:36 am
Maarten
  • 339
Bigger Brakes
« Reply #30 on: July 28, 2005, 11:13:36 am »
Rear calipers are noted for parking brake issues. Make sure the parking brake works & the bleed screw opens before you buy a used rear caliper
Audi A3, Golf Mk4/Jetta Mk4 aluminium rear calipers fit on scirocco/rabbit A2 carriers:
http://vwcaddyforum.com/showthread.php?t=5312
Because the calipers are aluminium and have an improved E-brake, problem solved  8)
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #31July 28, 2005, 11:30:47 am
vwpieces
  • 51
Bigger Brakes
« Reply #31 on: July 28, 2005, 11:30:47 am »
Quote from: "Maarten"
I agree but now the problem is proportioning. The larger piston needs more fluid. I read up on some issues trying to make those work & my solution was to sell the set I had & put the money twards a new set of rear calipers. I paid $20 for the aluminum ones & sold them for $120. That eased the pain alittle on the new rears $250pr. & alot less effort to make them work.
