Author Topic: cooling troubles  (Read 1907 times)
May 19, 2008, 03:45:19 pm
KAC
  • 35
cooling troubles
« on: May 19, 2008, 03:45:19 pm »
I have a 1.6 td in my suzuki buggy and i recently put the radiator into the rear...I plumbed the same s the front rad would have been...but it wouldn't circulate...any ideas..Air?...
thanks!
Suzuki samurai with VW TD
Reply #1May 19, 2008, 06:54:38 pm
flapjack
  • 283
cooling troubles
« Reply #1 on: May 19, 2008, 06:54:38 pm »
maybe a stuck thermostat?
signature
Reply #2May 19, 2008, 09:32:40 pm
Vanagoner
  • 219
cooling troubles
« Reply #2 on: May 19, 2008, 09:32:40 pm »
It sounds like you have the same trouble we have on vanagons.  Search for bleeding the cooling systems on vanagons, and make sure that your input and output are right on the rad.  One thing we do is park it on an angle with the radiator really low, and then bleed from the top of the radiator. run it to circulate and make sure you have a full reserve tank of coolant before you start.   top it up a lot.
Sage
