Author Topic: how does the speedo work on a late mk5 box?  (Read 6182 times)
Reply #15May 20, 2008, 05:48:47 am
gigaz2
  • 626
« Reply #15 on: May 20, 2008, 05:48:47 am »
thats some serious mod, a lot of risk for almost no return.
cheap and dirty way for a geek to do it: bicycle computer with the sensor coupled to the passenger side transmission (the part that doesn't move with the suspension).
I achieved to take mine to 85Km/h on a very steep incline :D so it doesn't seem to have a limit and you could avoid speed cams with that.
the accuracy increases a lot if you glue it to a rim, and have the sender in the caliper for instance.
Reply #16May 20, 2008, 07:00:29 am
RabbitGTDguy
  • 1274
« Reply #16 on: May 20, 2008, 07:00:29 am »
There are kits for custom motorcycles out there as well that use the same idea. Would be an easy install...
I wouldn't go the route that you were talking...err...cutting....welding....on the box itself...much easier ways to do it...
Joe
1972 VW Westfalia
Reply #17May 21, 2008, 03:28:17 pm
oldskool rich
  • 446
« Reply #17 on: May 21, 2008, 03:28:17 pm »
ok so i could use a bike speedo, trouble is that i need to then go from the pulse sensor to my anolog style clocks.
i know its alot of effort for nothing back, i spent the whole day hiding my aftermarket tacho metre inside the standard clocks of a mk1 scirocco, theres no way i did that for nothing. i need all the dials working. i want this to look totaly standard.
f6squared I.D.S.T
Reply #18May 21, 2008, 03:57:12 pm
snakemaster
  • 405
« Reply #18 on: May 21, 2008, 03:57:12 pm »
Hey man get a speedo cable of a beetle cos it goes to the front hub and the greese cap got a pin in it whitch turns the cable , you could mod this to fit the rear hub of your pickup need a bit longer cable thro , have a look at a beetle to see what i meen  :)
Reply #19May 21, 2008, 06:09:24 pm
oldskool rich
  • 446
« Reply #19 on: May 21, 2008, 06:09:24 pm »
safe, ill look into that
thanx
f6squared I.D.S.T
