Author Topic: 1.6 boost pin in 1.9  (Read 3128 times)
May 15, 2008, 10:22:48 am
flash319
  • 163
« on: May 15, 2008, 10:22:48 am »
I have an AAZ.
I have read through the "make your 1.9 faster" thread a few times and think I will do most of what is in there.  I was just wondering if I just change the boost pin to a 1.6 pin without changing anything else from stock (still have the clip on the max screw, max boost is still at 10-12 psi, K03) will I see any difference?
Should I add more fuel first like the thread says or should I change the pin first and see how I like it.  I don't want a ton of smoke.
And should I adjust my peak boost last when doing any modifications?
I want low end grunt because the engine is in a Toyota truck but I still need to rev it out to 3 grand on the hiway.
Reply #1May 15, 2008, 10:48:35 am
« Reply #1 on: May 15, 2008, 10:48:35 am »
Yes, the pin will allow more fuel with added boost, something the stock pin doesn't do.
Reply #2May 15, 2008, 11:10:57 am
MJF
  • 581
« Reply #2 on: May 15, 2008, 11:10:57 am »
1,6 pin is 11mm and 1,9 is 12mm. You could also grind the original pin to get the fueling you want/need
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #3May 15, 2008, 11:41:44 am
flash319
  • 163
« Reply #3 on: May 15, 2008, 11:41:44 am »
I thought they were a direct swap???
Reply #4May 15, 2008, 01:38:31 pm
geetus
  • 27
« Reply #4 on: May 15, 2008, 01:38:31 pm »
The pins are a direct swap. Use the 1.6 spring as well though.
One thing I am uncertain of is if you should keep the plastic bushing at the top of the 1.6 pin or not. I took mine off and it seems to run fine. Maybe someone can clear this up?
Reply #5May 15, 2008, 02:46:05 pm
MJF
  • 581
« Reply #5 on: May 15, 2008, 02:46:05 pm »
Quote from: "geetus"
1,6 pin will fit to 1,9 pump, but not otherwise. Does your 1,9 pump have starwheel under spring? My pump didnīt have. Throw the plastic bushing away, that is not needed :)
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #6May 17, 2008, 07:37:27 am
spencebm
  • 686
« Reply #6 on: May 17, 2008, 07:37:27 am »
so some of the 1.9 pumps have no starwheel to adjust the tension on the boost pin?  interesting.  so the 1.6 boost pin and spring are the way to go unless you want to grind your own 1.9 pin and keep the 1.9 spring?
Ben Spencer
