S-PAutomotive.com
Author Topic: Tbelt not tracking right  (Read 4591 times)
May 07, 2008, 09:32:54 pm
hamradio
  • 282
« on: May 07, 2008, 09:32:54 pm »
Ugh.
Getting my engine all back together, and now the tbelt won't track right.  Seems to be in the IP.  The belt is riding about 1/16" off of the IP pulley.  The bracket is tightly bolted to the engine.  The IP is tightly bolted to the bracket.  It's tracking about 3/16" away from where it used to (judging by the marks on the pulley).
Could it be, that I sandblasted and repainted the IP/motor mount bracket, and re painted it?
Any suggestions?
Reply #1May 07, 2008, 09:47:47 pm
« Reply #1 on: May 07, 2008, 09:47:47 pm »
Was it tracking good before the work was done to it?
It may not be mounted in the exact same location. I seem to recall reading that you can slightly move the brackets a bit
Reply #2May 07, 2008, 11:51:18 pm
Possum79
  • 276
    • http://www.poscarclub.com
« Reply #2 on: May 07, 2008, 11:51:18 pm »
1979 VW Rabbit Diesel L
My car may be ugly but im addicted to it.
Reply #3May 08, 2008, 07:54:44 am
hamradio
  • 282
« Reply #3 on: May 08, 2008, 07:54:44 am »
it was tracking perfectly before I took the bracket off.  I guess I'll take it off tonight and try to figure out what's going on.
Reply #4May 08, 2008, 03:39:11 pm
riddleyo
  • 130
« Reply #4 on: May 08, 2008, 03:39:11 pm »
Yea I had the same problem. The thread posted above was how I fixed it. I just followed the tech service bulletin that VW posted, checked all brackets and pulleys with a straight edge, and replaced a stripped nut/bolt on the IP bracket. I also painted my IP bracket, I don't think that should be a problem.
1985 VW Golf Diesel 1.6L N/A
My Build Thread: http://www.vwdiesel.net/forum/index.php?topic=14607.0
Reply #5May 08, 2008, 04:16:48 pm
hamradio
  • 282
« Reply #5 on: May 08, 2008, 04:16:48 pm »
where's the tsb?
Reply #6May 08, 2008, 05:48:19 pm
Possum79
  • 276
« Reply #6 on: May 08, 2008, 05:48:19 pm »
I think the service bulletin was deleted either by the poster or the moderators. I wish i would have printed it.
riddleyo did you save a copy? if so can you send me it via pm.
Reply #7May 08, 2008, 09:00:34 pm
hamradio
  • 282
« Reply #7 on: May 08, 2008, 09:00:34 pm »
ugh.
I think it's the ip bushing.  I started tearing it all apart again, and noticed about 1mm of play, maybe slightly less.  After turning it over several times the belt stays on, but sticks out about 1/16" over the ip pulley.
Next year, I'm putting a 16v in this car.  I've messed around with the diesel enough for a fun car, it doesn't have the dollar-hp factor I'd like, and I have all the wiring and fueling laying around for a full 16v swap.  The diesel will probably get thrown into a mk2 or something for a dd; I just hate this stuff that I'm not really sure what's going on.  I'd rather have a 16v and mess with wiring than mess with tearing my IP bracket off because it *might* be a reason my timing belt won't track right.
Reply #8May 08, 2008, 09:20:39 pm
« Reply #8 on: May 08, 2008, 09:20:39 pm »
Quote from: "Possum79"
We (the mods) don`t regulate content like that. If it`s porn or spam it`s gone, otherwise we leave it.
Don`t give up on the diesel :shock:
Reply #9May 08, 2008, 10:02:40 pm
hamradio
  • 282
« Reply #9 on: May 08, 2008, 10:02:40 pm »
I'll drive it this summer, but if it still isn't thrilling me at the end of the summer, out with it.  I'm limited to two cars; if I wasn't, I'd own a 16v scirocco.
I now need to find my gear puller to get the ip pulley off.  Then I'll jack the engine up a little, and try to get the bracket off.  It frustrates me that I just put all this stuff back on the engine a couple weeks ago, and something isn't right.  Ugh.  I had visions of having this thing running in the next week or two.
Sorry about all the ***ing.
Reply #10May 09, 2008, 12:35:44 am
Possum79
  • 276
« Reply #10 on: May 09, 2008, 12:35:44 am »
Quote from: "burn_your_money"
I realized after I said it the the creator of the it deleted it. No offense to any of the moderators by anymeans. I just wasnt sure untill I went OoOo it says he deleted it at the bottom of the post.
Reply #11May 09, 2008, 06:57:13 am
« Reply #11 on: May 09, 2008, 06:57:13 am »
none taken, just figured I should let people know what we do around here :lol:
Reply #12May 09, 2008, 01:10:43 pm
riddleyo
  • 130
« Reply #12 on: May 09, 2008, 01:10:43 pm »
Quote from: "hamradio"
I'll post the TSB in this thread when I get home today. I've used a gear puller on the IP pulley before, it takes forever. Now, I just used a long screw driver to pry against the IP pulley from behind, then tap the screwdriver with a  rubber mallet and it pops right off.
Reply #13May 09, 2008, 05:42:25 pm
riddleyo
  • 130
« Reply #13 on: May 09, 2008, 05:42:25 pm »
Hmm, I couldn't find the tech bulletin. But all it said was this:
Push the left side of this bracket down, and the right side of the bracket up, and then tighten the bolts down.
Reply #14May 09, 2008, 06:33:35 pm
hamradio
  • 282
« Reply #14 on: May 09, 2008, 06:33:35 pm »
Will try.  So, unbolt it from the motor mount bracket, loosen the 2 bolts, and move it, tighten them, and re bolt it to the mm bracket?
I just pulled the bracket off, rebolted it on, etc, and it still runs about 1/16" off of the pulley.  I'll go try the move the bracket trick.
Fixmyvw.com
