Author Topic: Breaking In  (Read 10105 times)
Reply #15May 11, 2008, 07:11:59 am
Breaking In
« Reply #15 on: May 11, 2008, 07:11:59 am »
Quote from: "TPW"
Another thing that I think is odd is that when the engine is cold there is very little oil mist going out the valve cover, but when it warms there is more.
My friend has the exact same problem with his AAZ. We believe we traced it to worn rings in cyl #1 but have not taken the engine apart to confirm this. We did a wet and dry compression test.
Reply #16May 11, 2008, 07:59:29 am
TPW
  • 113
Breaking In
« Reply #16 on: May 11, 2008, 07:59:29 am »
I'm trying to find an inexpensive compression tester to get more insight into this problem.
Reply #17May 11, 2008, 11:21:23 am
Breaking In
« Reply #17 on: May 11, 2008, 11:21:23 am »
Quote from: "TPW"
ebay has some cheap ones that work well.
Reply #18May 11, 2008, 06:24:24 pm
TPW
  • 113
Breaking In
« Reply #18 on: May 11, 2008, 06:24:24 pm »
I just bought one off ebay that I can test through the glow plug threads. I should have it by next week
Reply #19May 13, 2008, 10:31:27 am
Breaking In
« Reply #19 on: May 13, 2008, 10:31:27 am »
Quote from: "TPW"
be sure to disconnect the fuel stop solenoid when checking  :shock:  :lol:
Reply #20May 13, 2008, 05:17:36 pm
smoken u
  • 231
Breaking In
« Reply #20 on: May 13, 2008, 05:17:36 pm »
what grade of oil are you burning?
15w40? or thinner?
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
Reply #21May 13, 2008, 07:59:42 pm
TPW
  • 113
Breaking In
« Reply #21 on: May 13, 2008, 07:59:42 pm »
Rotella 15-40
Reply #22July 06, 2008, 02:19:38 pm
TPW
  • 113
Breaking In
« Reply #22 on: July 06, 2008, 02:19:38 pm »
I finally got around to pulling the head today.  I plan on replacing it with another, but I noticed there was a lot of play in one of the exhaust valves.  even with the pressure of the cam on it it moves about 1/4 inch side to side.  I think the valve guide is gone.  Would that cause this much oil consumption?
Reply #23July 06, 2008, 02:56:50 pm
gigaz2
  • 626
Breaking In
« Reply #23 on: July 06, 2008, 02:56:50 pm »
yes, and your lucky it hasn't run away. haven't you said that the valveguides were replaced?
Reply #24July 06, 2008, 03:53:15 pm
TPW
  • 113
Breaking In
« Reply #24 on: July 06, 2008, 03:53:15 pm »
Yes they were just replaced less than 3000 miles ago.  What caused them to go out so fast?
Reply #25July 06, 2008, 04:54:29 pm
gigaz2
  • 626
Breaking In
« Reply #25 on: July 06, 2008, 04:54:29 pm »
someone put a wrong diameter guide? only a possibility, but either way, the machine shop should be responsible for that.
Reply #26July 06, 2008, 09:59:34 pm
Breaking In
« Reply #26 on: July 06, 2008, 09:59:34 pm »
or an inferior valve guide... magnesium would last a long time  8)
Reply #27July 07, 2008, 04:57:18 am
TPW
  • 113
Breaking In
« Reply #27 on: July 07, 2008, 04:57:18 am »
Who sell magnesium guides?
Reply #28July 07, 2008, 07:21:34 am
saurkraut
  • 904
Breaking In
« Reply #28 on: July 07, 2008, 07:21:34 am »
Quote from: "jtanguay"
magnesium?
Are you thinking Managese Bronze (CDA 863)?  Known as Mag Bronze, Its good for heavy loads at low speed.
The stock Bronze valve guides are actually top notch, it used to be an upgrade for the US built engines to go to bronze valve guides from their POS iron guides.
I don't know what the stock guide alloy is.  Befor we condem the stock guides right straight to heck, maybe we should find out what the alloy is.  It could very well be mag bronze all ready.
My job involves working with (and knowing, to a certain extent) allot of different alloys.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #29July 07, 2008, 07:49:47 am
gigaz2
  • 626
Breaking In
« Reply #29 on: July 07, 2008, 07:49:47 am »
this ones lasted 3000miles... I doubt they are stock, or someone put the wrong ones in.
