Author Topic: Concerned about RPM's  (Read 4296 times)
Reply #15May 17, 2008, 06:19:55 pm
James8485
  • 223
« Reply #15 on: May 17, 2008, 06:19:55 pm »
i drive approx 200k's per day the motor was rebuilt but i dont use a drop of oil in between oil changes, thats driveing 115-120KM/H at 2900-3200RPM
if the motor is in good shape you shouldn burn any oil, mine burned a crap load untill i had the rebuild done. ppl kept telling me theres supost to burn oil! well a motor thats in good shape and all seals are good shoulnt as mine doesnt! and i do alot! i mean alot of highway miles!
---------James--------
Reply #16May 17, 2008, 06:44:21 pm
The Mad Hatter
  • 85
« Reply #16 on: May 17, 2008, 06:44:21 pm »
well, i've switched routes to work to a smaller highway with a 55mph speed limit.  HOPEFULLY, running at 3k rpm will be better that 4k.  I'll keep an eye on it.
I had the timing belt and valve cover gasket done by a shop, perhaps its missing that baffle?
Reply #17May 17, 2008, 09:06:12 pm
hamradio
  • 282
« Reply #17 on: May 17, 2008, 09:06:12 pm »
Huh.  Before I tore apart my engine, I got 32 mpg consistently, running 3rd gear up to about 60 often, flooring it everywhere, and dropping into 3rd or 4th on the highway quite often, and using higher revs a lot. :D
Reply #18May 18, 2008, 05:03:36 am
The Mad Hatter
  • 85
« Reply #18 on: May 18, 2008, 05:03:36 am »
well, running at 4k rpm and 75mph, i got 37mpg, but it was burning oil too fast for my comfort.
