Author Topic: just some quick clarification please. senders  (Read 3802 times)
May 04, 2008, 01:14:56 pm
cal
  • 49
« on: May 04, 2008, 01:14:56 pm »
hi guys would just like to know which senders ser which on my 1.6 sb (no a/c or pas).
i had a look on vag cat but i can't make head nor' tail of it :(
so if someone could help me identify the water temp and pressure senders, along with the oil pressure senders?
thanks in advance guys :)
Reply #1May 04, 2008, 01:48:09 pm
Turbinepowered
  • 1206
« Reply #1 on: May 04, 2008, 01:48:09 pm »
So far as I know, you don't have a water pressure sensor.
Are you referring to where to find them, or looking for part numbers?
Reply #2May 04, 2008, 01:56:23 pm
cal
  • 49
« Reply #2 on: May 04, 2008, 01:56:23 pm »
where to find them sorry!
Reply #3May 04, 2008, 03:19:19 pm
Turbinepowered
  • 1206
« Reply #3 on: May 04, 2008, 03:19:19 pm »
Where to buy them, I can't help you with that.
Where to find them on the engine is easier. If it's set up like the typical 1.6TD, the oil pressure senders will be atop the oil filter mount and screwed into the back of the head (the end opposite the cam sprocket). These are the high pressure and low pressure senders, respectively.
The coolant temperature sensor for the cluster will likely be on the water outlet at the rear of the head (again, opposite the cam sprocket). The glow plug relay temp sensor will be on the same outlet, but a separate sensor. Both of these are likely the small, single-connection type.
Any help?
Reply #4May 04, 2008, 03:48:17 pm
cal
  • 49
« Reply #4 on: May 04, 2008, 03:48:17 pm »
great thanks! any chance of some pics so i can get a clearer idea?
Reply #5May 05, 2008, 05:32:39 am
GTD.
  • 183
    • http://tinyurl.com/6yk84
« Reply #5 on: May 05, 2008, 05:32:39 am »
Your turbo will also have a temperature switch on the banjo connector for the water inlet on the top of the turbo this is to switch on the coolant pump to cool the turbo when you turn the engine off
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #6May 05, 2008, 10:51:33 am
cal
  • 49
« Reply #6 on: May 05, 2008, 10:51:33 am »
i've got the aux pump running perminatly anyway (well when the ignition is on) so should keep the turbo pretty cool :)
Reply #7May 05, 2008, 11:22:12 am
GTD.
  • 183
« Reply #7 on: May 05, 2008, 11:22:12 am »
except when its supposed to, when the engine is off :shock:
[Oo=w=oO]Golf GTD
Reply #8May 05, 2008, 12:47:53 pm
cal
  • 49
« Reply #8 on: May 05, 2008, 12:47:53 pm »
doesn't matter, when it pop's i've got a bigger one to replace it  :P
anyway back on topic, senders for guages?!?!?
Reply #9May 05, 2008, 09:10:35 pm
GTD.
  • 183
« Reply #9 on: May 05, 2008, 09:10:35 pm »
1 028 919 081 D oil pressure switch 0.25 BAR M10X1 1 pin blue
2 056 919 081 E oil pressure switch 1.8 BAR M10X1 1 pin white
2 068 919 081 oil pressure switch 1.4 BAR M10X1 1 pin black
2 068 919 081 A oil pressure switch 0.9 BAR M10X1 1 pin grey
3 N   013 811 5 seal A10X13.5
8 049 919 501 temperature sender for coolant, oil temperature indicator and glow plug relay 0-125C m10x1 1 pin black 23,28 GBP
13 171 959 481 A thermal switch 119C M22x1.5 2 pin black
13A N   013 827 1 seal A22x27
25 251 919 501 D temperature sender for coolant temperature gauge 18,09 GBP
33 191 919 521 C temperature switch turbocharger 12,92 GBP
[Oo=w=oO]Golf GTD
Reply #10May 06, 2008, 02:37:02 pm
cal
  • 49
« Reply #10 on: May 06, 2008, 02:37:02 pm »
yea, i guess i could... for the sake of running it in :)
cheers for the diagarm buddy :)
