Author Topic: New injectors = Blown turbo  (Read 4690 times)
April 29, 2005, 12:33:20 am
DVST8R
  • 535
« on: April 29, 2005, 12:33:20 am »
Well I just noticed recently that my #2 injector had a slow leak. I am leaving on a trip to Edmonton tomorrow. So I had ordered some GTD nozzles, to go in untill I sort out the mess with the "BIG" injectors. I took some spare "cores" I had gotten from Dave took the nozzles and cores to Justin and BD and he set them up to 160 Bar as requested by me.
Later that evening Dave came over for some exhaust work so I had Dave pulled out my old injectors and put my new ones in while I worked on his downpipe. After a long evening, Mark and I had a chance to go for test drive. After letting the car warm up I decided to see what these things were like and opened it up we were in second gear making 22psi when it "popped and whirred" and then there was just a lot of smoke and no boost, so I started home and noticed that we had a big cloud following us. I thought mabey I had popped the HG, after nearly a year of 22psi +, with testing hitting 35psi +, got just about home and the oil light came on so I shut off the car and coasted the rest of the way. We put the car in the shop, the back of the car was covered in oil, and the exhaust was dripping oil. I pulled off the intake and the turbo was frozen in place. All of this a day before I need to leave for Edmonton.
So this morning I called a few people and tracked down a turbo, went picked it up and spent the better part of the day wrestling the old one out and the new one in. As it turns out the only turbo I could find was a KKK, vs my garrett that blew up. So I will give a run down of performance differnce in a week or two when I return from my trip. Regardless got the new turbo in went for a drive, everything was very smooth good power, really quick boost. Drove it with stock boost at 12psi or so for about 15min just listening and watching the gauges, everything looked fine so I took it back to the shop and hooked up my electronic boost controler. Set it for 19PSI and went for a drive.  :D  :D  :D  So smooth and quite. Power wasnt up huge, but I despritly need more air and cooler air, I have smoke on demand and any rpm and at any boost level, still waiting on a new intercooler and to put my second turbo in.
Full report in about two weeks.
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #1April 29, 2005, 12:51:02 am
autobahn
« Reply #1 on: April 29, 2005, 12:51:02 am »
nothing like the clan to help you get going :wink:
[putting on flamesuit]
Reply #2April 29, 2005, 01:08:02 am
DVST8R
  • 535
« Reply #2 on: April 29, 2005, 01:08:02 am »
wouldn't it be Klan power :roll: ??? I have always wondered why borg warner went with the triple kkk's?
Reply #3April 29, 2005, 11:06:54 am
TDIMeister
  • 284
« Reply #3 on: April 29, 2005, 11:06:54 am »
Borg-Warner did not choose the unfortunate name, "KKK."  KKK existed long before Borg-Warner acquired it over several years ago, and the acronym is short for "Kühnle, Kopp & Kausch" which is the full name of the German company.
The company's official name has been changed several times since the acquisition, to 3K-Warner, and now, BorgWarner Turbo Systems.  As for the Ku Klux Klan references, it is a term primarily familiar only in North America.  Along the same vein, some may ask why Borg-Warner would want to have its name associated with an alien race that wants to assimilate all of humanity...  :roll:  :lol:
Reply #4April 29, 2005, 02:11:10 pm
acidwarp
« Reply #4 on: April 29, 2005, 02:11:10 pm »
"Along the same vein, some may ask why Borg-Warner would want to have its name associated with an alien race that wants to assimilate all of humanity... "
white supremacist trying to assimilate humanity? if its what you are saying, just for your knowledge, it is completely the opposite since white suprem. dont want to get mixed with other "races"...
ok enough politics.
Reply #5April 29, 2005, 02:20:53 pm
TDIMeister
  • 284
« Reply #5 on: April 29, 2005, 02:20:53 pm »
It was meant to be lighthearted, a.k.a. a joke, a.k.a an attempt at humour.
Reply #6April 29, 2005, 03:41:56 pm
acidwarp
« Reply #6 on: April 29, 2005, 03:41:56 pm »
lol, ok because im actually doing an essay about the subject, and there is so much biased information from both sides, i felt the need to intervene
oh and i have a question regarding the turbos, is it possible to make it work earlier, instead of 4000rpm, lets say 3200rpm ?
Reply #7April 30, 2005, 05:01:47 am
Patrick
  • 1034
« Reply #7 on: April 30, 2005, 05:01:47 am »
Turbos respond to heat/pressure/energy in exhaust. If you want it to spool sooner, you need more heat sooner. More fuel means more heat..............  I have two, and they both have a lot of boost a lot sooner than 3200.
Other possibility is a smaller turbo. It will react a lot faster.
Reply #8April 30, 2005, 08:16:11 am
TDIMeister
  • 284
« Reply #8 on: April 30, 2005, 08:16:11 am »
Or get a turbo whose turbine has a smaller numerical A/R ratio.
Reply #9April 30, 2005, 11:46:23 am
935racer
« Reply #9 on: April 30, 2005, 11:46:23 am »
If you have a 2.5 downpipe and a 3 inch exhaust they spool up very very quickly, trust me :twisted:
