Author Topic: turbo spools down when I shut down  (Read 4927 times)
April 18, 2008, 06:57:11 pm
trent77
  • 217
« on: April 18, 2008, 06:57:11 pm »
Even when I let the car set about 30 seconds at idle, the turbo still spools down when i shut the car off. I have not noticed this in any of my previous turbo diesels.  I just don't like the turbo moving after oil has been shut off. It's a 94 aaz. thanks for any input
91 (former)eco jetta now aaz (sold to Ben)
05 passat tdi (sold)
77 westfalia
06 GMC Duramax
10 Jetta sportwagen tdi
81 Rabbit pickup (Caddy)
Reply #1April 18, 2008, 07:18:02 pm
truckinwagen
  • 1895
« Reply #1 on: April 18, 2008, 07:18:02 pm »
the turbo will be turning as long as there are exhaust gasses coming from the motor, so even at idle the turbo is spinning fairly fast, and it will take a moment or two for it to come to a stop after you turn off the motor.
I wouldn't worry as there is still plenty of oil present for the moment of spinning after the oil feed is cut off.
83 Opel Kadett Diesel
Reply #2April 19, 2008, 03:30:54 am
haybayian
  • 155
Re: turbo spools down when I shut down
« Reply #2 on: April 19, 2008, 03:30:54 am »
Quote from: "trent77"
This was of concern to me too. Starving the turbo is I believe the greatest risk we face (yes, yes, not everyone agrees).  My solution (which I concede is extreme) was to set up the turbo with its own lubrication system, i.e oil can, filter, electric pump and oil radiator as well as an oil pressure and oil temperature dumb lights. If you look at my posts you will find a discussion of the subject as well as pictures.
Good luck.
Haybayian
Keep it simple if you can.
Reply #3April 19, 2008, 05:25:40 am
foxracer1
  • 991
« Reply #3 on: April 19, 2008, 05:25:40 am »
If it's just coasting there no way it will damage its self due to lack of oil. If it spins that long its because the turbo is in good shape.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #4April 19, 2008, 06:42:50 am
Baxter
« Reply #4 on: April 19, 2008, 06:42:50 am »
Surely going to the expense of fitting the turbo with it's own lube system is more expensive that the Turbo itself?
Seems a tad pointless to me.
Reply #5April 19, 2008, 07:27:32 am
haybayian
  • 155
« Reply #5 on: April 19, 2008, 07:27:32 am »
Quote from: "Mr Brick-Yard"
The cost of the whole system was  around $375 (from memory). My turbo cost three times that.
Reply #6April 19, 2008, 07:44:07 am
spencebm
  • 686
« Reply #6 on: April 19, 2008, 07:44:07 am »
listen to foxracer!
Ben Spencer
Reply #7April 19, 2008, 08:34:31 am
bert
  • 423
« Reply #7 on: April 19, 2008, 08:34:31 am »
mine spins at shut down,nothing to worry about,just be more concerned about good quality oil,good filters,and regular changes  :wink:
Bert
Reply #8April 19, 2008, 02:14:06 pm
trent77
  • 217
« Reply #8 on: April 19, 2008, 02:14:06 pm »
thanks everyone. I appreciate all the input. My little aaz is running very well and I wanted to keep it that way! I'm still a bit disappointed with the fuel mileage though, only around 36-39mpg. I figured dropping it into an a2 would have gotten me above 40. Tires are good, and it doesn't spoke when I accelerate, but I can live with it no matter what. thanks again.
Trent
77 westfalia
06 GMC Duramax
