Author Topic: Fuel Coolers - How beneficial are they?  (Read 8971 times)
April 26, 2005, 11:10:55 pm
vwmike
  • 1158
« on: April 26, 2005, 11:10:55 pm »
A post from another thread got me thinking about fuel coolers. A few months ago i ran a can of diesel hi-test through my truck and after it had been running for a while the contents of the can were steaming it was so hot.
The same way charge air becomes heated due to pressure generated by the turbo, fuel would also be heated by the injection pump. Obviously the pressure is much higher so the temperature rise should be higher. On the good side, it has that whole tank of fuel in the back to mix with and cool down....but the lower you are on fuel, the hotter the fuel would become.
My question is: For our purposes, how beneficial would it be to keep temperatures in check?
Reply #1April 27, 2005, 06:46:47 am
steve
  • 70
« Reply #1 on: April 27, 2005, 06:46:47 am »
Incompressible liquids do NOT heat up when pressurized the same way as compressible fluids (air) do.  Fuel becoming heated upon exit from an IP may happen, but it has nothing to do with the the thermodynamic reasons that a turbo heats the air.  I suspect that it's mostly just from plain old conduction heat transfer.
Take me back to Colorado...........  84 Quantum 1.6L TD 470K miles, 2003 Jetta TDI 95K
Reply #2April 27, 2005, 07:24:23 am
QuickTD
  • 1156
« Reply #2 on: April 27, 2005, 07:24:23 am »
Most of the heat generated within the pump is the result of windage. Stirring any viscous fluid will generate a fair bit of heat.
 I would like to have some kind of thermostatic regulation of fuel temperature just for consistancy in performance. My car smokes a fair bit when its cold but as it warms up the fuel loses density and the power (and smoke) falls off a bit. It would be nice to have a consistant fuel temperature of 90ºF or so. I was considering a pelteir cooler of the type used in "Koolatron" type coolers. It would have the advantage of being able to heat the fuel in the winter as well. Might be a bit technical but I have the necessary parts in stock, now I just need the time...
Reply #3April 27, 2005, 08:37:03 am
fspGTD
  • 1529
« Reply #3 on: April 27, 2005, 08:37:03 am »
I found relocating the fuel filter in the passenger fender was effective in helping to keep the fuel cool and maintaining consistent performance.
I had the worst fuel temperature problems when I was running a short exhaust system terminating after the shift boot with a turn-down before the fuel tank.  During an 800 mile road trip the turn down fell off, and the hot exhaust blew directly at the fuel tank!  Performance was noticeably down as a result.
Jake Russell
Reply #4April 27, 2005, 10:01:43 am
vwmike
  • 1158
« Reply #4 on: April 27, 2005, 10:01:43 am »
Quote from: "steve"
Ah, for some reason that fact esxaped me in my moment of brainstorming. I wonder if it's still worth trying sometime.
Reply #5April 27, 2005, 11:16:36 am
steve
  • 70
« Reply #5 on: April 27, 2005, 11:16:36 am »
Things don't always work the way we hope.  But, the nice thing about this forum is that we're all trying to come up with some neat stuff and help each other out.  I think it's great.
Reply #6April 27, 2005, 12:22:04 pm
vwmike
  • 1158
« Reply #6 on: April 27, 2005, 12:22:04 pm »
I guess a better question would be how fuel temperature affects performance. I've never really seen any reference to this, but does anyone have any data to shed some light on this?
Reply #7April 27, 2005, 12:47:13 pm
steve
  • 70
« Reply #7 on: April 27, 2005, 12:47:13 pm »
I read somewhere that the IP was already temp compensated.  I dono if it's true since I have no data...
Reply #8April 27, 2005, 04:33:02 pm
chrissev
  • 694
« Reply #8 on: April 27, 2005, 04:33:02 pm »
Quote from: "steve"
for my SVO conversion (in progress) I have rerouted the fuel return line with a t-fitting so that the returned fuel goes directly back into the injection pump rather than back to the tank.  This was necessary to keep vegetable oil out of the fuel tank.  I wonder if this will affect performance?  I always thought the hotter the fuel, the better the viscosity, the better the atomization that the injector is able to produce.  Maybe I am wrong?
Reply #9April 27, 2005, 04:46:17 pm
racer_x
  • 123
« Reply #9 on: April 27, 2005, 04:46:17 pm »
I think this is an area where diesel requirements are different than gasoline requirements. In a diesel, you want the fuel to burn immediately when it squirts out the injector. On a gas engine, you want the fuel to not burn until the spark plug fires, and the cooler the fuel, the less likely it will explode from compression heat.
Other than a slight density advantage, I don't see cold fuel as being an advantage on a diesel engine. You might get a little more in, but it will take longer to atomize and burn, too. If you're trying to run highr RPM's for higher horsepower, that's going to hurt more than it helps.
Reply #10April 28, 2005, 04:08:23 am
« Reply #10 on: April 28, 2005, 04:08:23 am »
I have some peltier 350W coolers if anyone is interested in trying a fuel cooling device.  All you need is a big enough heatsink on the hot side, and the cold side will get extremely cold :D
I also thought of using the power generating peltier's to generate the power from the turbo exhaust to power the peltier cooler (not as hard on the battery/alternator)
Reply #11April 28, 2005, 07:15:33 am
VWRacer
  • 649
« Reply #11 on: April 28, 2005, 07:15:33 am »
Quote from: "vwmike"
The coefficient of volumetric expansion for diesel is 0.00046 per degree F, so if the temp of the fuel rises 100F between the tank and the injector pump, each stroke of the pump injects about 4.6% less fuel than if the fuel were 100F cooler. That will definitely affect performance, since the power of a diesel is pretty much directly proportional to how much fuel is being injected.
Stan
C-Sports Racer
Reply #12April 28, 2005, 08:45:19 am
vwmike
  • 1158
« Reply #12 on: April 28, 2005, 08:45:19 am »
Quote from: "VWRacer"
Alright, that is the answer I was looking for  :D
The only thing I was really able to come up with before was heat and it's relative effect on viscosity. I didn't really think about expansion rates. Thanks!!
Reply #13April 28, 2005, 11:06:05 am
diffdude
  • 39
« Reply #13 on: April 28, 2005, 11:06:05 am »
someone needs to try one of these and see if there is a increase in power.            http://store.summitracing.com/default.asp?Ntt=fuel+cooler&Ntk=KeywordSearch&DDS=1&searchinresults=false&N=0&target=egnsearch.asp
81 caddy 1.6 td, 2.5" turbo back, snow performance water/meth injection, and all the other usual mods.
Reply #14April 28, 2005, 11:27:46 am
vwmike
  • 1158
« Reply #14 on: April 28, 2005, 11:27:46 am »
I was just going to hook an automatic transmission cooler into the return line (those are cheap and/or free). I would think putting it on the feed would probably make the pump have to work too hard to draw in the fuel.
